I recently moved into a house where the previous owner put in a shed and ran two 10/2 w/Ground UF cables to it, and connected both cables to a 20A twin breaker with handle ties. The other end in the shed is barely finished but one cable is going to a few outlets and one to a few lights. A few questions:
Is this even to code/safe? Not sure if it violates the "only one circuit to an outbuilding rule". There doesn't appear to be any ground rod installed, but I understand with a 20A breaker I don't necessarily need one?
Could I put both cables into a sub panel to get 110/220 if I need it in the future? If so, how should I handle the neutrals? Hook both up to the neutral bus bar or only use one? My gut is only one should be used
