Retired Moderator
That is typical if an old shellac finish--after cleaning with mild soap and water, the old finish can be desolved with alcohal---look up 'french polish' a trip to the library might help---see if they still have a copy of 'The Furniture Doctor'---that old book had directions on emulsifying an old shellac finish.
As to the lifting veneer---you may be able to inject glue under it and clamp it back into place.
the lifting veneer is due to the hyde glue releasing its grip. hyde glue is water based and will release when exposed to enough moisture.
if you back a board with a protective rag, and clamp it over the lifted section, you may be able to re-secure it. do this before refinishing, as the rag may leave marks.
or you could leave it, since it is 100 yrs old.
