just searching the web for some answers to a problem I have with a breaker panel and saw your website - wondered if you could give me some suggestions about my situation. I moved into a small cottage that was built - probably in the early 1980s. The main panel is 100 amps but the bus bar is so small, only has 12 slots and I need more. I can do installs on fixtures, wiring and getting that sort of job done but have never tackled any panel or subpanel work. I want to put in a washer and dryer but have no slots for this. Can I put in a 100 amp subpanel off the main, taking out 2 of the current breakers for feeding the subpanel, and then have some breakers in the subpanel to work with? It would be much easier to just take out the old panel and put in a 200 amp, or possibly just a larger bus bar in the existing box (?) but the box looks like a snake pit with wires everywhere spliced into the breakers so I am not wanting to do that. I also can't pay for an electrician to do the work, and am told I'd need to get the electric company to turn off the power so I could do the box change, none of this is feasible for me. What do you think is the best approach? Thanks in advance for your help. see some images of the situation here:
http://www.flickr.com/photos/[email protected]/?saved=1
