Good morning all,
I have a 4 gang box plastic and a need to connect 10, 14 awg ground wires. Red wire nuts are max 6, 14 awg wires and if I understand correctly for CA code each device has to have its own ground so I cant daisy chain ground from switch 1 to switch 4 then to main ground branch?
Whats ideal way to connect the grounds together? Can / Should I use a greenie and terminate all 6 romex wires together with 1 longer wire to then wire nut / join 4 pigtails from the switches?
Devices / wires:
1) power in 14/2
2) outside lights 14/2
3) front porch 14/2
4) entry light 14/2
5) 3 way 14/3 out to 2nd switch
6) power out 14/2
Forgive the sloppy art, trying to plan the termination for rough-in inspection before I start.
Thought it best create a new post but link to old post with some relevant info
4 Gang Box Wiring / Crimping Question
