Hi all, I just moved to a new house, and was going to hook up my 4 prong dryer when i realizes the new house had a 3 prong receptacle. So I popped off the receptacle cover to see if by some miracle it had a ground in it and I could switch out the 3 prong receptacle to a safer 4 prong. Well to my surprise it did have a ground, but, the ground was being used as the neutral as it was only 10/2 wire. My wife was nagging me to get the dryer working so I thought well they've used it like this for this long must be ok and ran to the store and bought a 3 prong dryer wire and gave my wife the reigns to the dryer. But I keep rethinking my decision and wonder if I should find a way to run new wire from the basement to the second floor laundry room, which would not be an easy task.
So my question... is my current wiring set up ok and shouldn't be a problem or should I change it out asap? I do not want to put my house or family in jeopordy and will chase the new wire if needed.
Also, since I did chage the dryer from a 4 prong to a 3 prong should have I bonded the dryer to neutral?
Thanks in advance for any help.
