Looking for suggestions on how to best pull a 4 6ga feeder wires for a hot tub from the breaker box in my garage through the exterior wall. My 200A panel is recessed into the wall in the garage so it is flush. The meter box is directly on the back of this on the exterior side of the garage, so I can't punch a hole through the back of the panel to come through the wall to a pull box. Easiest path is to exit the bottom of the breaker box (sides have studs on them), but in a 2x6 wall cavity I am not left with enough room to fit a curved 1" elbow fitting. If I did that, it would leave the box on the outside floating about 2" from the wall. Is there another type of fitting suitable for in-wall concealment that has a lower profile? Seems there are limited options for 1" conduit, most of them converting to liquid tite conduit.
Options I can think of are:
Thanks for any thoughts
- I could run a few feet of NM cable in the wall cavity and then convert to THHN in a junction box on the outside of the garage, but it seems like an unnecessary connection with some heavy gauge wire.
- I could run a short section of armored conduit from the panel to a squeeze clamp that would connect to the conduit box via thread connectors
- Drop down from the bottom of the panel with PVC and then use a 90deg sweep fitting to go to the side (stay in wall cavity) and then out the back of the garage (through about 6 studs) and into an LB conduit box. Photos of my panel and meter box attached.
