I'm removing a rats nest of duct tape and wire run from a home exterior wall to what can be loosely called a shed. I only found one UF romex at 120, so that should be easy enough to box up, but there's also a set of three stranded #14 wires that are duct taped together. I'm getting ~1.5V and ~2.3V between a couple of the wires, and there's a string of what appear to be low voltage lights nearby. Is that voltage coming from those, or could it be coming from some of the spa equipment that still has an active and separate 120 line run to it?
