Hi All,
I made a rookie mistake and ran a 1/2" copper gas line (inner diameter) that has a 5/8" outer diameter.
I plan on flaring my pipe and using a flare nut, however the pipe won't fit through my 1/2" flare nut.
If I use a 5/8" flare nut, will the threads also be 5/8" ? I need to connect the pipe to an existing 1/2" OD shut off valve.
Is there such thing as a 5/8" flare nut that has 1/2" threads?
· Master General ReEngineer
Nope,... Dependin' on how ya look at it, ya ran the wrong size line, or ya just gotta Adapt what you've got, to what ya need....
Btw,... Most flarin' tools, Don't do 5/8" copper tubin'....
Your not trying to flare hard copper tubing are you?
Is this tubing going behind a wall? Any place I've lived you have to use steel pipe not copper.
Also In a lot of places it's againt the law for a home owner to even work on gas lines.
