I have a problem with my air conditioner only when the outside temperature is above 90. It cuts off after about 15 minutes. It may come back on and then cut off again as I drive but gets worse the longer I drive. I have already had the system evacuated and recharged.
The Hybrid has a Auto setting you can use to set the temperature and the system will use heat or air to maintain the temperature. Using this or the manual method appears to be the same; however, some times I can increase the temperature and the fan speed to maintain the cool air a little longer. It appears to me the compressor is fine since when I get air it is plenty cold.
Could this be a sensor or something more invasive like the compressor? The shop wants $300 just to diagnose it.
