Installing A Toilet - Beginner - How To Guides - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Like Tree23Likes
Old 02-07-2017, 07:02 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,364
Re: Installing a toilet - Beginner
Originally Posted by 123pugsy View Post
Remote controlled toilet?? Far out!!!! Oh boy... I guess I really am an old F---. I can't even imagine why I would need a remote control for a toilet... are you likely to use it when you are not close to it?
Looks like a PIA to install. Mostly, because, it looks as though you need to reach in through the access panels to get at the bolts.
Do you have a receptacle beside your toilet? lso, you need to verify where your supply pipe comes in match the spec sheet.
Flange needs to be 12" rough in from rear wall. Most toilets are already.
But, it's doable and we can walk you through it as long as your willing to keep posting back.
(Just a possible note... I have never installed a TOTO, but my neighbor had me over trying to figure out/solve the smell in his lower basement area. We poured castor oil in the floor drain, pulled up some carpet to insure there was not slab/stem wall leakage, checked plumbing connections and he assured me that he had already had a guy out who had RE-installed the seal/flange on the new Toto to be sure that was not the problem.....
Well.. third try was a charm... it turned out to be the seal on the Toto... I was not there, but Bob had him out a third time... so either the guy was not proficient with that install, or it can be tricky.)
Good luck.... (So what do the buttons on the remote control do??????)
MTN REMODEL LLC is online now   Reply With Quote
Old 02-07-2017, 08:18 PM   #17
Property Mgt/Maint
Rewards Points: 8,210
Whats great about the sponge is when you miss the bolts and crush the seal, you just pick up and try it again!
Here is my goto
Yodaman is offline   Reply With Quote
Old 02-08-2017, 04:49 AM   #18
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,766
Heated seat warmer and fan I believe and probably the radio.
123pugsy is offline   Reply With Quote
Old 02-08-2017, 06:56 AM   #19
Property Mgt/Maint
We sure have come a long way from the outdoor shed with a wooden seat.
http://www.totousa.com/washlet%C2%AE...128-gpf-09-gpf
This beauty cost more than my first two cars...........combined.
Old 02-08-2017, 09:02 PM   #20
Rewards Points: 366
I would like to recommend a tube of clear caulk or whatever color you need to seal around the base of the toilet and the floor.
DallasCowboys is offline   Reply With Quote
Tags
installation , toilet , toilets
Installing a toilet in concrete 3Dsigns Remodeling 1 11-25-2014 12:57 PM
Installing an Offset Toilet Flange JohnC20 Plumbing 13 04-17-2014 05:21 PM
installing plastic toilet flange ratherbefishing Plumbing 1 06-16-2012 02:30 PM
Installing a new toilet flange - before or after tiling WoodmanFL Plumbing 9 01-21-2012 08:29 PM
installing tile. Toilet against the wall joemcjr Building & Construction 4 02-16-2009 08:49 PM
