I Can Skim Coat That Wall In Less Then 10 Minutes! - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Like Tree7Likes
  • 3 Post By Sir MixAlot
  • 1 Post By ClarenceBauer
  • 1 Post By cleveman
  • 1 Post By flipflopper
  • 1 Post By christoff
Old 01-01-2018, 03:30 PM   #1
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 1,170
I can skim coat that wall in less then 10 minutes!
I’m on a remodeling project where I’ve installed some new drywall and did the drywall finishing. Now we’re ready to skim coat for a nice smooth finish. So, I figured why not get the skim coating process of just one wall on video and share it with everyone so they can learn just a couple skim coat tips and tricks.
The thing with skim coating a wall is that it can bring an otherwise ugly wall back to a nice new and flat surface. Walls are typical damaged over time, after wallpaper removal or even from a bad drywall job.
So here's my video. Let me know what you think or if you have any questions that I can maybe answer for you. Thanks for watching! -Paul
I’ll be using a 12 inch drywall taping knife, mud pan, and some all-purpose joint compound then down to a yogurt consistency.
More info on the tools and materials used on my Blog post: http://www.texturemaster.com/skim-co...l-tips-tricks/
-Paul
Checkout my YouTube Channel with 75,000 Subscribers and over 12,000,000 Views
https://www.youtube.com/paulpeck
Sir MixAlot is offline   Reply With Quote
Old 01-01-2018, 08:52 PM   #2
Rewards Points: 322
Re: I can skim coat that wall in less then 10 minutes!
Sir Mixalot you need to try the Master of Plaster product someone with your skills could about double your profits with the product. Don't let the cost scare you off before i retired i was getting any where from $9.50 per Sq. /Ft. up to $ 12.50 Sq. / Ft. for two base coats & a smooth finish. Depending on height & scaffolding required. You can use a Magnesium Slicker and cover 42 inches in one stroke also filling in low spots. for a high polish finish mist with water from a spray bottle or use a blister brush the finish will shine.
Sir MixAlot likes this.
ClarenceBauer is online now   Reply With Quote
The Following User Says Thank You to ClarenceBauer For This Useful Post:
Sir MixAlot (01-01-2018)
Old 01-02-2018, 03:11 PM   #3
Rewards Points: 1,002
Looks very good! I have a whole house which I need to go through and re-sink the nails (they are all in pairs) and skim all the walls, repair some outside corners, etc.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Sir MixAlot (01-02-2018)
Old 01-02-2018, 03:40 PM   #4
Yes. I have a slicker too. Finally someone calls it that. I usually get corrected and told it's a Darby mate! Hahaha.
Really, I just wanted to do a video to help all the Do it Yourselfer's out there. I get so many questions on Youtube about skim coating, that I thought this project was a good opportunity to show the process of skimming a wall.
So, maybe a motivated DIY'er can get an otherwise ugly wall back to it's original luster.
Take care, -Paul
-Paul
Old 01-02-2018, 03:48 PM   #5
Thank you so much @cleveman !
Oh, skim coating a whole sounds like fun. If I had a whole house to skim coat, I would use the old paint roller trick to make it go a lot quicker.
-Paul
Old 01-02-2018, 04:54 PM   #6
Rewards Points: 64
Definitely learned a lot. I know enough to know how much experience you have. Wish I could say this would only take me 10 minutes. More like 100.
flipflopper is offline   Reply With Quote
Old 01-18-2018, 11:24 AM   #7
Thats awesome @flipflopper !
Skim coating a wall might take you longer than me. But, with these videos you now have the skills to skim coat your walls on your own.
Take care, -Paul
-Paul
Old 01-18-2018, 05:26 PM   #8
Super Moderator
Gymschu's Avatar
Rewards Points: 316
SirMixAlot, you never disappoint with your videos. If I don't make it to Heaven, I know what I'll be doing in the "other place." Skim-coating. Do I like the final results of doing it? Sure. But what an ugly, dirty, rotten job it is to get to the finished product. At least your videos make it LOOK like fun.
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following User Says Thank You to Gymschu For This Useful Post:
Sir MixAlot (01-18-2018)
Old 01-18-2018, 05:53 PM   #9
Rewards Points: 309
You do have a good point but I as well enjoy my finished product.
christoff is offline   Reply With Quote
Old 01-27-2020, 04:32 PM   #10
Rewards Points: 2
I know this is an older thread, but I wanted to stop by and say thank you so much for it! I learned a lot in this video and can't wait to use it! We have some horribly damaged walls in our home and I spent HOURS on the small bathroom alone that we are finishing up just to make the walls look presentable. We still have the rest of the house to do. I'm planning on using these tips on the next room and cannot wait to see the outcome!
nerelda is offline   Reply With Quote
Tags
diy , diy drywall , skim coat , skim coating , skimming
Skim Coat over Primer cougar01 Painting 32 12-14-2017 08:54 AM
thin skim coat ok on wall before installing mosaic? cubangt Tiling, ceramics, marble 0 07-24-2017 10:53 AM
After Skim Coat...Gardz or 123??? Help!!! j2dabizo Drywall & Plaster 3 09-06-2012 07:26 AM
Can I use Hendry 547 Unipro skim coat over Henry 555 or 565 SLC? jellybeanjugler Flooring 1 07-02-2012 07:08 AM
Paint Over Skim Coat? Please Help Canoe Place Painting 2 09-01-2011 05:04 AM
