Precooling Refrigerator Coils - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 01-09-2020, 12:51 PM   #1
Rewards Points: 22
Precooling refrigerator coils
I will be installing a heat pump water heater soon. It will move a lot of cold to the interior, but was thinking of using some of this to feed into the fridge's heat rejection coils. Does anybody have ideas on duct size to feed air to the coils? I already had a metal shop create a manifold box to direct the cool air to the cellar and to help dry the clothes.
Kurt
Sent from my SM-N960U using Tapatalk
KurtP is offline   Reply With Quote
Old 01-09-2020, 02:17 PM   #2
Rewards Points: 2,924
Re: Precooling refrigerator coils
These units aren’t intended to have duct fastened to them. And refrigerators have minimum ambient temperatures in which they can run. Cool air isn’t necessarily going to make it cool better.
roughneck is online now   Reply With Quote
Old 01-09-2020, 08:08 PM   #3
Rewards Points: 150
This will be counter-intuitive, but as long as the fridge cooling coils are not clogged with dust, directing colder air over them will not have any impact on the efficiency of the unit. The only way to use the cooler air to effect the efficiency of the fridge would be to cool the air around the fridge itself, reducing its cooling requirements, but that would be difficult to do.
If you would like a more technical explanation of why that is, let me know.
Chris
Chris616 is offline   Reply With Quote
Old 01-11-2020, 09:15 PM   #4
Commercial. Const. ret.
surferdude2's Avatar
Rewards Points: 2,156
What kind of refrigerator do you have... I mean is it a large size unit that may have a thermostatic expansion valve as opposed to a smaller unit with a capillary tube for metering the refrigerant flow?
I need to know what continent you live on before giving advice.
surferdude2 is online now   Reply With Quote
