How To Bind Two Round Metal Rods Together? - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Like Tree11Likes
Old 07-09-2018, 11:00 PM   #1
Rewards Points: 4
How to bind two round metal rods together?
I have a towel holder exactly like this one:
Basically one of the bars that hold towel broke clean off the holder base, exactly at where the soldering joints are (or perhaps they are called welding joints?). The break point is pretty clean and the bar can be put back seamlessly, now only if there's something that can re-bind it to the holder base?
flykoko is offline   Reply With Quote
Old 07-09-2018, 11:13 PM   #2
Rewards Points: 3,916
Re: How to bind two round metal rods together?
Just saying good morning but have no easy solution. I'm not optimistic that any type of glue or epoxy will stand a chance. Basically it would need to be braised or welded but the process would be rather involved and probably well beyond the value of that rack. What would be the cost of replacing the unit with a new one. That sets the upper limit for what can be spent on a repair.
Bud
Bud9051 is offline   Reply With Quote
Old 07-10-2018, 06:59 AM   #3
JUSTA MEMBER
Rewards Points: 1,620
Before replacing it, try a package of J B Weld, two part epoxy.
The one for metals similar to your item.
There are different kinds of J B Weld. get the one for the material being held together.
No guarantees, because the force that broke this off in the first place might be too much for it.
And it ain't a trapeze, so no swinging from it.
ED
Guap0_ likes this.
de-nagorg is offline   Reply With Quote
Old 07-10-2018, 07:27 AM   #4
Rewards Points: 1,466
If copper a repair may work ( no guarantees of course ) if a gusset, possibly 2, is soldered or J B welded in addition to the butt joint.
SeniorSitizen is offline   Reply With Quote
Old 07-10-2018, 08:22 PM   #5
Rewards Points: 1,700
Nothing but a weld will support even the weight of a damp towel. Suggest you file it down smooth so no one will notice that one rod is missing.
Bondo and Domo like this.
ChuckF. is offline   Reply With Quote
Old 07-11-2018, 07:09 AM   #6
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,042
it will be way cheaper to just go buy another one just like it
if you are in love with that design. if you are flexible, buy one
that is a bit more beefier that will hold bath towels without breaking.
there is no adhesive or epoxy in the world that will fix it.
I have a TIG welder: and to weld it back on will distort the metal,
burn off the chrome plating, and just look ugly.
I see those online between $18 and $40.... just buy another one.
jus my Dos Centavos
Johnny_inFL is offline   Reply With Quote
Old 07-11-2018, 08:26 AM   #7
Still learning every day!
F250's Avatar
Rewards Points: 616
What he (Johnny inFL) said ^^^.
Buy another one. Simpler. May or may not be cheaper. Regardless, you wan't have a hack job staring you in the face every time to reach to either hang or retrieve a towel. When replacing, consider getting a more sturdy replacement.
Pete
Bark less, wag MORE, and Show Compassion to everyone you meet!
F250 is offline   Reply With Quote
Old 07-11-2018, 08:45 AM   #8
Buy another piece of china crap to replace the one that failed.
de-nagorg likes this.
Old 07-11-2018, 02:12 PM   #9
F250's Avatar
Rewards Points: 616
The last sentence in my post negates exactly what you imply I was saying. I never promote buying "China crap".
Pete
Old 07-11-2018, 02:20 PM   #10
What I said was, that's our only choice.
Old 07-11-2018, 04:04 PM   #11
JUSTA MEMBER
Unless you have access to your own machine and fab shop, you are stuck buying what the market sells.
CRAP.
ED
Old 07-11-2018, 05:04 PM   #12
F250's Avatar
Rewards Points: 616
You might not want to pay for it, but you can get these products from sources where they are "Made in USA"...
http://www.bellacor.com/made-in-usa-...-and-rings.htm
Pete
The Following User Says Thank You to F250 For This Useful Post:
de-nagorg (07-11-2018)
Old 08-02-2018, 09:47 AM   #13
CodeMatters's Avatar
Rewards Points: 5,964
Duct tape and coat hanger.
----------Red Green
MTN REMODEL LLC likes this.
CodeMatters is online now   Reply With Quote
Old 08-28-2018, 07:44 AM   #14
Rewards Points: 2,342
Is it still under warranty?
I have a two piece pivotable tower bar with similar design by DornBracht not made in China but made in Germany, the platinum finish wore off two years ago and they replaced it no question asked. I bought it 5 years ago and it did cost around $180 when it was on sale.
If it's a cheap Bed Bath & Beyond item then I would just get a new one no sense wasting time to repair.
miamicuse is offline   Reply With Quote
Old 08-28-2018, 08:06 AM   #15
Guapo
Rewards Points: 11,950
J B Weld was the first thing that came to my mind too. That's about your only chance as far as an epoxy goes.
Guap0_ is offline   Reply With Quote
Installing Simonton 5500 Reflections Double Hung BOX With Half Round Attached. JohnRoss Windows and Doors 2 05-09-2018 01:12 PM
Grounding Metal Boxes and Outlets - Confused by Something Simple ALFisher Electrical 42 04-28-2015 12:14 PM
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
Round metal lamp post DJM1955 General DIY Discussions 11 08-27-2012 02:32 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
