Have Soffit Vents? Check Them. - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Like Tree7Likes
  • 1 Post By captfl2x
  • 2 Post By Nealtw
  • 1 Post By Gymschu
  • 2 Post By Gregsoldtruck79
Old 09-08-2019, 08:09 PM   #1
Rewards Points: 152
Have soffit vents? Check them.
Alabama last 2 weeks temps of 92-96 degrees. Because of soil type, almost all homes are on slabs. HVAC are in attics. I have an older home and last few years I've had more insulation blown in (twice). The ranch style hip roof leaves very little vertical height to work in. My HVAC over works with a setting of 77 degrees with these high temps. I was curious if I had insulation blocking any soffit vents or preventing air flow to attic. Including the attached, floored, and non insulated garage, there is a total of (35) 8" x 16" soffit vents. When I pulled the firs vent, I knew there was a problem with the vents. The vent opening was only 6" x 12". Worst than that was the vent had about 90% blockage with paint and "crud". All vents had an estimated blockage of 30% to 90%. All vents were replaced with new. Instead of each vent being placed between rafters, 27 of the 35 vents had a 2"x4" blocking the opening. So each of these had opening loss of 6 square inches. Over the next few weeks, I will add 13 additional vents to reach the desired "free air flow" square footage. I wish I had taken attic temp readings before and after---but didn't. I do know that the HVAC is cycling more and the non insulated garage is even cooler now.
Dave Sal likes this.
captfl2x is offline   Reply With Quote
Old 09-08-2019, 08:17 PM   #2
retired framer
Rewards Points: 20,406
Re: Have soffit vents? Check them.
Do you ave air chutes in every bay between rafters?
Gymschu and Dave Sal like this.
Do not use flat bottom gables with scissor trusses.
Old 09-08-2019, 08:53 PM   #3
Super Moderator
Gymschu's Avatar
Rewards Points: 6,848
I'm a painter and on a recent house repaint, I offered to replace paint-blocked vents. Much to my surprise, half of them were just "dummie" vents. Someone just screwed the vents into soffit wood and didn't bother to cut out the wood so there would be air flow!!! I would say UNBELIEVABLE, but knowing how GC's operate and/or a subcontractor on a time schedule works, it's more common than you'd think. Glad you're getting your blocked vents taken care of.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 09-09-2019, 08:22 AM   #4
Rewards Points: 152
No air chutes except where some remodeling was done with access to where chutes could be added. I cleared 2 areas at the top wall plates. all the rest were good. Adding air chutes else where means insulation would be destroyed again. Decided against it.
Gymschu likes this.
Old 09-09-2019, 08:35 AM   #5
retired framer
Then don't calculate the vents, calculate the square inches of the chutes.
Usually you have air chutes with just enough bat insulation under it over the wall to hold the loose in place,
Old 09-09-2019, 11:44 AM   #6
Rewards Points: 1,872
Good thread....
Here is another one to watch out for, if your home had the standard of 3/8 " plywood level soffits and then a contractor has encapsulated it with vinyl/metal. As they did on our 1960 model home, way long before we bought it. .
While working on our hot attic issue, I pulled one of the "perforated" vinyl soffit panels out to check to see the condition of the original soffit vents that should have been located right above the perforated vinyl air intake panel.
I found the original old 8" x 16 " metal vent in the old plywood, with only about 4 inches of one end of it, being ventilated through the perforated vinyl panel. So in the pic, I just installed another perforated panel beside it to get the old vents full ventilation used. All while thinking maybe the house just had one vent covered. Nope....
After checking all the rest of our homes level soffits perforated vinyl vents, I found that 6 more of them were not even close to the old original 8" x 16" soffit vent. So I spent some time cutting in more 8" x 16" soffit vents centered over the top of vinyl perforated panels.
Gregsoldtruck79 is online now   Reply With Quote
Old Yesterday, 09:43 PM   #7
Rewards Points: 40
I've seen it all too. I did a video in 2014 on exactly this topic. Fortunately with continuous soffit vents, the issue has gotten better.
Attic Ventilation Troubleshooting:
AtticFoil.com is offline   Reply With Quote
