Wooden Deck Waterproofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 05-26-2019, 09:37 AM   #1
Solutions (handyman)
Rewards Points: 492
Wooden deck waterproofing
I just renovated a 16 x 4' balcony and used PT 3/4" plywood for the floor. I would like to water proof it and my client left it up to me as to the type of surface. Living in Canada, weather changes from 80 to -30 so I am asking about recommended products. Are the liquid rubber products good or what might be recommended. Thanks.
Mark Harvey is offline   Reply With Quote
Old 05-26-2019, 09:56 AM   #2
retired framer
Rewards Points: 13,402
Re: Wooden deck waterproofing
What did you remove, maybe you should have asked before installing a wet plywood.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-26-2019, 09:59 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,538
Are you enclosing it?
Or just wanting to protect the below from rain.
Nealtw likes this.
Old 05-26-2019, 12:33 PM   #4
Rewards Points: 492
The old deck was partially rotted, un treated plywood. The new deck is a balcony with no sides (other than railing, and no roof or awning.
Old 05-26-2019, 12:39 PM   #5
retired framer
What ever you do it should go up the wall behind the siding and paper 6 or 8 inches and under the door threshold and most if not all require dry plywood.
I would be looking at solid surface vinyl decking like tuffdeck or fiberglass
figure 7-14
Old 05-26-2019, 03:15 PM   #6
Rewards Points: 492
Thanks, That is a good consideration. There is also a liquid textured rubber that I've heard of, but don't know much about it. I am familiar with Duradeck and Tuffdeck. Thanks for the input.
Old 05-26-2019, 03:28 PM   #7
retired framer
The paint on stuff was terrible 30 years ago and it might be better now but I haven't seen it used for 30 years either.
figure 7-14
Porcelain tile outside over wooden deck porch SEYON General DIY Discussions 38 10-22-2014 08:49 PM
Miscellaneous deck questions NewHomeDIYGuy Building & Construction 38 09-17-2012 02:41 PM
wooden swing, wooden deck chair m.macdonald Painting 2 06-09-2011 09:07 AM
Wooden deck stripping handiandi Painting 5 05-26-2005 12:20 PM
Firepit on elevated wooden deck handiandi Building & Construction 6 08-19-2004 11:25 PM
