Waves In Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 11-14-2018, 09:01 AM   #16
craig11152's Avatar
Rewards Points: 1,212
Re: Waves in roof
My latest armchair theory is a combination of vertical plywood and shady side condensation.
Plywood should never go on a roof vertical unless its nailed to horizontal purlins .
roofermann and Nealtw like this.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 11-14-2018, 09:12 AM   #17
retired framer
Rewards Points: 14,706
Re: Waves in roof
They may have missed the H clips too. I am thinking solid blocking could push it back up.
Old 11-17-2018, 12:46 PM   #18
Rewards Points: 64
Re: Waves in roof
They did use H clips -- that I know. Few pics attached. The level is a four footer and ttle sticks are chop-sticks from a Chinese takeout place. The key question: Can this all wait another four or five years until I had planned to replace the roof or am I in trouble now? Thanks!
agd202 is offline   Reply With Quote
Old 11-17-2018, 12:59 PM   #19
retired framer
Re: Waves in roof
Usually we expect dips to be between the trusses, you have a low truss. That should be easy to find on the inside and make sure it is not cracked or broke.
We always crown lumber and put crown up, once in a while a piece can change for what ever reason and sag. I would give that a good inspection from the inside.
Old 11-17-2018, 01:28 PM   #20
Rewards Points: 64
Re: Waves in roof
Can do. What should I look for? In the rafters and in the underside of the plywood? What's bad look like?
Old 11-18-2018, 01:08 PM   #21
Rewards Points: 64
Re: Waves in roof
Pics from inside the attic. No water stains, no mold on underside of plywood. No vertical cracks in the rafters, but some horizontal cracking. Not sure if this is a sign of something bad, or if every 45 year old house has cracks like this in the rafters. All thoughts welcome!
Waves in roof-img_0525.jpg   Waves in roof-img_0526.jpg   Waves in roof-img_0527.jpg   Waves in roof-img_0528.jpg
GAF TPO? Should whole roof be stripped? leeleses Roofing/Siding 9 06-18-2018 06:25 AM
Deck Roof Addition (Bad Idea?) EG97 Roofing/Siding 12 12-23-2017 12:22 PM
When to replace an old cedar roof camner Roofing/Siding 2 09-13-2014 09:07 AM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 01:55 PM
