Wanted: Owens Corning Canyon Red 3-Tab Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree6Likes
  • 1 Post By craig11152
  • 1 Post By m_ridzon
  • 1 Post By NotYerUncleBob2
  • 2 Post By Yodaman
Old 03-11-2019, 10:28 AM   #1
Licensed Pro. Engineer
Rewards Points: 466
This is a cross-post from the Classifieds forum, in an attempt to get more visibility from the roofing folks...
My home has Owens Corning "Canyon Red" 3-tab shingles. O-C has discontinued these. However, I have some blown off and need to replace them. I'm not sure if anybody here has some stowed away that I could buy, but thought I would at least ask.
m_ridzon is offline   Reply With Quote
Old 03-11-2019, 10:43 AM   #2
craig11152's Avatar
Rewards Points: 1,180
Re: Wanted: Owens Corning Canyon Red 3-Tab Shingles
Certainteed and Tamko still make a "tile red" 3 tab I believe.
They won't be a perfect match but even if you had extra OC's from the original job they wouldn't look the same depending on how long the existing shingles have been in the sun.
Yodaman likes this.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 03-11-2019, 10:55 AM   #3
Rewards Points: 466
Yah, I have Certainteed Coral Frost, which somewhat matches, but not identical (O-C is a little darker shade). I can use the Certainteed, but thought I'd take a shot here, to see if anybody wanted to get rid of their Canyon Red surplus, in exchange for a little cash.
Nealtw likes this.
Old 03-11-2019, 11:06 AM   #4
craig11152's Avatar
If I had done your roof in the good old days I would have left you 10-12 shingles, any thing left from an open bundle just for this occasion.
m_ridzon likes this.
Old 03-11-2019, 11:06 AM   #5
Rewards Points: 860
Call around to your local roofers, but they may only be interested in you if you hire them to do the work too.
The other option is Habitat for Humanity or any local reStore or other material salvage seller.
NotYerUncleBob2 is offline   Reply With Quote
Old 03-11-2019, 11:20 AM   #6
Property Mgt/Maint
Rewards Points: 6,238
Do a search to find the OC distributors. Then start checking for old inventory. The big box stores would rotate their inventory, but you might get lucky with smaller distributors.
craig11152 and m_ridzon like this.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 03-11-2019, 11:37 AM   #7
retired framer
Rewards Points: 14,012
When we had a Re Store the Home Depot would dump old inventory all the time with them.
Do not use flat bottom gables with scissor trusses.
Wanted: Owens Corning Canyon Red 3-Tab Shingles m_ridzon Classifieds 0 03-11-2019 10:26 AM
Owens Corning True Definition Max weight DanielGanfield Roofing/Siding 2 02-01-2019 06:16 AM
Trouble removing shingles in 100F gunner66 Roofing/Siding 8 11-09-2017 06:05 AM
owens corning shingles oakwood 40 yr failed in 11 yr nodiehl Roofing/Siding 5 09-19-2008 08:27 PM
Owens Corning vs. GAF wojogirl Roofing/Siding 1 07-24-2007 11:44 PM
