Tying A Metal Roof Into A Shingle Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By BigJim
Old 09-10-2019, 10:39 PM   #1
Rewards Points: 60
Tying a metal roof into a shingle roof
We have a shingle roof at about a 6/12 pitch over our garage. Want to add a covered porch behind it. Covered porch will be about a 4/12 pitch. So will be framing it up with 2x6s and then 1x3s on top to screw the metal panels to. Question is how to tie the new metal roof into the shingle roof? Obviously I will have to try and lift up some of the shingles and then I'm guessing use some flashing tucked up under the existing shingles and then on top of the new metal panels? Or is there a better way?
ponch37300 is offline   Reply With Quote
Old 09-10-2019, 10:50 PM   #2
retired framer
Rewards Points: 20,634
Re: Tying a metal roof into a shingle roof
How are you tying the structure to the building?
Do not use flat bottom gables with scissor trusses.
Old 09-10-2019, 11:45 PM   #3
Rewards Points: 60
Going to run 2x6s as rafters and will land on the garage trusses. This porch roof won't be big or have much weight on it. My main concern is how to tie the new metal roof into the existing garage shingle roof and how to flash that.
Old 09-11-2019, 12:07 AM   #4
retired framer
I would want about 10" of flashing on the 6/12 with half of it under the upper shingles. And seal the bottom of the flashing to the metal roof so the wind can't blow water up there.
Roofers will be along.
Old 09-11-2019, 12:21 AM   #5
retired framer
Have you seen this.
roofermann likes this.
Old 09-11-2019, 04:20 AM   #6
roofermann's Avatar
Rewards Points: 677
Great example, Nealtw. Ideally the shingle roof potion of the transition flashing should extend past where the bottom row of shingles is nailed.
roofermann is online now   Reply With Quote
Old 09-11-2019, 07:16 AM   #7
Rewards Points: 2,761
Presumably the OP will be adding a new downspout?
huesmann is online now   Reply With Quote
Old 09-11-2019, 07:25 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,668
Have you seen this.
I did mine just like that and it leaks, not in the house but runs down onto the asphalt shingles under the metal roofing. I would suggest making the bends in the flashing and at the transition point closer. I had to install an additional flashing under that flashing to make it stop leaking and it still leaks with a really hard rain.
It doesn't hurt anything as it just slightly drips on the treated, sealed floor of the porch. Make sure the rubber gromet that goes under the metal flashing onto the metal roof is back away from the edge of the flashing. You want as much flashing over hanging the gromet as possible.
Nealtw likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
