Tarp To Temporarily Stop Skylight Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree5Likes
Old 02-25-2018, 12:39 PM   #1
Rewards Points: 30
Tarp to temporarily stop skylight leak
I'd like to find a way to secure a tarp over a leaky skylight without using nails (which is the only approach I can find online; I don't want to make more holes in my roof). One thought was to tie a rope around the tarp and skylight and setting a 2x4 and a few bricks on the up-roof side. I know this is not nearly as leak-proof as good as using nails to secure the tarp and 2x4s, but is it a reasonable option? Other approaches? Thank you.
RS
riversurf58 is offline   Reply With Quote
Old 02-25-2018, 02:01 PM   #2
Rewards Points: 6,554
Re: Tarp to temporarily stop skylight leak
If the roof is dry silicone adhesive sealant or any of the other multitude of adhesive sealant products will seal the edges down.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
riversurf58 (02-25-2018)
Old 02-25-2018, 02:38 PM   #3
Rewards Points: 826
You could use cloth pipe sock cut to length tie off one end fill with sand tie off & place on sides and top leave bottom open this will hold the tarp in place. I have made my own using drop cloth cut a sew the up fill with sand works great.
ClarenceBauer is online now   Reply With Quote
The Following User Says Thank You to ClarenceBauer For This Useful Post:
Old 02-25-2018, 02:39 PM   #4
Rewards Points: 30
@SeniorSitizen : So, do mean run a bead of sealant to afix the tarp to the shingles right above the top edge of the skylight? Thanks.
Old 02-25-2018, 02:56 PM   #5
I have no idea where your sky light is leaking so cut a piece of tarp or plastic to cover it completely plus about a foot on all sides and adhere all the outer edges with adhesive.
No one could determine where ours was leaking so when we re-roofed I solved the problem by pitching it in a dumpster.
Dave Sal and CodeMatters like this.
Old 02-25-2018, 03:01 PM   #6
Rewards Points: 30
I like this idea and will pick up a sock & some sand to have it ready for the next leak, which is just a matter of time. Thanks.
Old 02-26-2018, 04:35 AM   #7
Rewards Points: 1,536
If shingles, use 1x furring strips and screws. To repair, lift up the tab a bit, osi quad caulk over the hole, then another dab top of the shingle. Anything else, prime and tape with eternabond tape.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
riversurf58 (02-26-2018)
Old 02-26-2018, 07:58 AM   #8
Rewards Points: 1,222
On the upper side of the light I would either tuck the top part of the tarp under a row of shingles (I would tack it, but if you want to try adhesive that is up to you, FYI, you would tack it so the nail is underneath a shingle tab, caution is needed with cold shingles though, they can break).
If the light is near a peak of a roof, you could drape the top part of the tarp over the other side then just hold it down with sand bags or whatever you where considering.
My point here is, just laying a tarp over a roof with some weight on it isn't going to create a water tight seal and water would still get under the upper part of the tarp.
Better yet, why don't you try to find the leak and tar or silicone it?
CrazyGuy is offline   Reply With Quote
The Following User Says Thank You to CrazyGuy For This Useful Post:
Old 02-27-2018, 10:50 AM   #9
craig11152's Avatar
Rewards Points: 1,220
Do you know if the skylight itself is leaking or the shingles/flashing at the roof line?
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 02-27-2018, 11:16 AM   #10
Rewards Points: 30
The leak was at the flashing/shingles. It's sealed up now, but I want to be prepared to move quickly if another leak does occur.
Old 02-27-2018, 11:27 AM   #11
Property Mgt/Maint
Rewards Points: 8,202
Forget the tarps, and keep a new gallon of roof cement on hand. A un-opened can probably has a 2-3 yr shelf life.
On the next re-roofing, I would be loosing those skiylights. But that's just my opinion of them. Lots of people love them, and when installed properly last many years.
CrazyGuy likes this.
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
riversurf58 (02-27-2018)
Old 02-27-2018, 11:30 AM   #12
retired framer
Rewards Points: 15,658
The tarp has to go up and over the peak of the roof to keep water out.
At the corners of the tarp, wrap a tennis ball in the tarp and tie a rope around it so now you can tie the tarp with the rope to something around the house fences trees what ever. Then you only have to worry about wind. running the rope to the corner and across to the other corner and then down the other side of building can help with wind.
The Following User Says Thank You to Nealtw For This Useful Post:
Old 02-27-2018, 11:33 AM   #13
retired framer
Most times they are not high enough, we build a frame out of 2x6 or 2x8 on edge under them. But that gives you no chance of insulation.
Old 02-27-2018, 11:50 AM   #14
Rewards Points: 30
Will applying the roof cement work while it's still raining? The labels say Yes, but, it's a label...
Old 02-27-2018, 11:58 AM   #15
retired framer
Is the ink on the label water soluble.
Ac freezing Lines - Pls help stop this leak !!!! xclaim HVAC 11 08-05-2015 07:59 AM
What is this and can I just tighten to stop leak? vcsolit Plumbing 12 01-06-2015 12:47 PM
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
Best way to tarp roof? jogr Roofing/Siding 3 06-05-2009 02:34 PM
Leak inside a skylight apt94jesse Roofing/Siding 2 09-23-2007 06:00 PM
