T-1-11 Siding Bottom Rot Repair. Need Advice - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree16Likes
Old 09-10-2017, 12:39 PM   #1
Rewards Points: 6
T-1-11 siding bottom rot repair. Need advice
There is some rotted t-1-11 on my mother's garage, It's all on the bottom 3" or so. Is there a small scale fix or should I cut horizontal and replace with a new t-1-11 strip or some type of 1x6 or other trim board with z flashing? Also it seems the last person installed a flashing on the bottom of one side, not even the whole side. Im thinking this is just holding moisture? Thanks.
T-1-11 siding bottom rot repair. Need advice-15050650083981674883052_1505065051667.jpg   T-1-11 siding bottom rot repair. Need advice-1505065160539992432139_1505065177706.jpg
Shurley0714 is offline   Reply With Quote
Old 09-10-2017, 12:51 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,576
Re: T-1-11 siding bottom rot repair. Need advice
The only way to "fix" it is to remove it and reinstall a new sheet that isn't as close to the ground and has proper flashing on it.
If you are okay with a slightly different look, you can install some PVC trim board on the bottom after you cut back the measured amount (i.e. 3.5" for some 1" by 4" PVC) and install a proper Z-bar flashing up behind the bottom edge of the T1-11 prior to the installation of the PVC trim board.
Only issue is that you have to do it all the way around to look right.
47_47, mark sr and Nealtw like this.
Old 09-10-2017, 01:23 PM   #3
Rewards Points: 6
The whole bottom will need to be done for the most part, but I seen a video on YouTube where they cut horizontal and applied caulking in between the top piece and new bottom strip they repaired, is this not a good way?
Old 09-10-2017, 01:36 PM   #4
Super Moderator
Gymschu's Avatar
Rewards Points: 6,826
As a painter, I've had to repair that T-111 many times using different methods. WOW's way works well as you just have to cut off the rot and then apply a trim board. PVC is great because it won't rot and can touch the ground without wicking up moisture. Wood is ok too, but you will want some sort of barrier underneath it where it hits the ground or it will rot in short order.
You can do it as you are planning to do, but, you still have to deal with the moisture problem at the bottom and the repair piece(s) you put in will rot just like what's happening now. The PVC trim idea is best in my humble opinion.
And, to be perfectly honest, T-111 is fairly cheap, so, removing the whole sheet is a good option too. Then you can replace it with engineered T-111 OR Fiber Cement T-111 which can be painted and won't rot.
"In the heat of battle, my father wove a tapestry of obscenity........."
Gymschu is online now   Reply With Quote
Old 09-10-2017, 05:12 PM   #5
retired painter
Rewards Points: 1,666
I wouldn't rely on caulking to keep it sealed! sooner or later the caulk will fail. Flashing is more/less maintenance free and works well.
mark sr is online now   Reply With Quote
Old 09-10-2017, 10:12 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 2,154
That would only be a stop-gap solution and leave you with the siding still down to the grade, which is the cause of the rot in the first place. I had a similar problem with my shed and rimmed it with 2x8 PT capped with flashing then new siding. I've changed the grade but if the PT rots in my lifetime I can unscrew and replace it. Also, painting or staining the sides and edges of your wood siding, not just the face, will help extend its life.
Nealtw likes this.
lenaitch is offline   Reply With Quote
Old 09-10-2017, 10:27 PM   #7
retired framer
Rewards Points: 20,072
I would use flashing tucked up behind the house wrap but not shoved up tight the the bottom of the siding, prime and paint the fresh saw cut to.
Buy material after cutting because you may find other problems with the framing and the best plans can be changed.
Nealtw is offline   Reply With Quote
Old 09-10-2017, 10:32 PM   #8
Usually Confused
lenaitch's Avatar
Exactly what I encountered. I had to replace a bunch of studs that looked ok from the inside but were rotten on the siding side (no wrap or subwall - just siding on stud. It's been a PITA but easier and cheaper than tearing in all out, re-doing the pad, permits, yada, yada.
Nealtw likes this.
Old 09-10-2017, 10:42 PM   #9
retired framer
We worked on a wall just above the roof of a church, inside the wall started 20 above stairs. to save the drywall inside we removed 4" of 2x6 studs and bottom plate and added new 2x4 bottom plate and new studs and saved the drywall inside.
The engineer had asked for the bottom 6" of sheeting replaced because it was swelled up.
Old 09-14-2017, 06:46 PM   #10
Rewards Points: 6
Thank you all for the advice. Pvc trim and z flashing sounds good because of how it got rotten in the first place, if I do replace the whole t-1-11 panel though I will look into the ones that don't rot or install flashing under the new panel.
Old 09-14-2017, 07:15 PM   #11
Naildriver
chandler48's Avatar
Rewards Points: 4,114
Note, too, you have 4" oc T1-11 and 8" oc wide RB&B simulated T1-11, so you have two animals to tame. I think the bottom trim board and z flashing will work just fine on both.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-14-2017, 07:48 PM   #12
kwikfishron's Avatar
Rewards Points: 320
If you do this you should add blocking in between the studs so the siding has full perimeter nailing. This is important for two reasons.
1) if the bottom of the siding is only secured with a nail at each stud then soon the siding will become wavy due to lack of support.
2) if the siding is also the sheathing on the wall you'll lose shear strength since the sheet is no longer connecting the top and bottom plates.
chandler48 and Nealtw like this.
kwikfishron is online now   Reply With Quote
Old 09-15-2017, 03:11 AM   #13
Rewards Points: 6
Not really sure how to block in between studs for this? So you're saying go in the garage and place 2x4's horizontal all the way around where the bottom of the siding will be after I place the pvc lumber and flashing? If so how often should nailing be?
Old 09-15-2017, 04:09 AM   #14
retired painter
If I understand the question correctly, the siding and bottom trim would have an additional nail or two into the blocking. Install the blocking after you cut the bottom of the T-111 but before you add the flashing and PVC trim.
kwikfishron likes this.
Old 09-15-2017, 04:35 AM   #15
Naildriver
chandler48's Avatar
Agree. Just cut 2x4's the width of your stud bays (usually 14 1/2"), and with the bottom portion of the siding off, insert the 2x4 up across the bottom of the dangling siding between bays and attach it with short decking screws, leaving half of it showing below the dangling siding. That way the top portion of the siding is supported across and the trim and bottom portion of new siding will be supported as well.
Larry......
Need advice on how to properly replace worn-out dryer vent on vinyl siding StoopidMonkey81 Building & Construction 5 06-25-2015 03:02 PM
How to repair my roof truss - cut bottom chord darlingm Roofing/Siding 10 01-05-2012 07:48 AM
Advice on siding issue Marqed97 Remodeling 8 07-23-2011 08:35 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
