Siding And Roofing Access Quick Questions - Don't Know What It's Called. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree10Likes
Old 06-17-2020, 06:04 PM   #1
Rewards Points: 185
Siding and Roofing Access Quick Questions - Don't know what it's called.
So first off, what this little added decorative roof/outcropping officially called?
Secondly, what's the best way to access it? It's just out of my reach while I'm on the garage roof. I was think about using something like a pivit ladder tool and a 6' ladder, but maybe some sort of scaffolding would work better, or a combination of the two.
Thanks for any suggestions or pointing me in the right google direction.
Siding and Roofing Access Quick Questions - Don't know what it's called.-m5ix0np.jpg
52Caddy is offline   Reply With Quote
Old 06-17-2020, 06:24 PM   #2
Rewards Points: 1,713
Re: Siding and Roofing Access Quick Questions - Don't know what it's called.
It's not really decorative, IMO. Looks like someone simply put on an addition with a different pitch. Are you saying it's too steep to stand on?
If so, you should probably get a Guardian Ridge It anchor... put it under the ridge cap at the peak (as close as you can put it to the chimney) and then get yourself a fall protection harness and rope... and learn how to use them.
But you normally should not access a roof from a step ladder at all. It's a great way to tip the ladder over. You should be using an extension ladder. And so that it does not rest on the gutter and dent it, you can put a stabilizer/standoff on the extension ladder.
XSleeper is offline   Reply With Quote
The Following User Says Thank You to XSleeper For This Useful Post:
52Caddy (06-17-2020)
Old 06-17-2020, 06:28 PM   #3
retired framer
Rewards Points: 15,110
something like this.
Siding and Roofing Access Quick Questions - Don't know what it's called.-52c-1.png
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
Old 06-17-2020, 06:42 PM   #4
Rewards Points: 185
You're right, it looks like an addition, but it's not, all original to the build.
It's not too steep, it's just not wide enough, maybe 18" tops, so it's not like I can crawl up there. I can reach the left corner from the garage roof, but about 1/2 to the right side it's just too far. I think something like Nealtw drew up is the way to go.
The other side of the house has something similar, but it's closer to 3' wide, that has enough room to get on top of.
Old 06-17-2020, 06:51 PM   #5
retired framer
We built a few like that where they have a max sq foot on the lot so they just make one side smaller and do this to the other side for a matched look.
52Caddy likes this.
figure 7-14
Old 06-17-2020, 06:58 PM   #6
Rewards Points: 185
Cool, thanks for the info. I think I'll probably go with something like you sketched up.
Old 06-17-2020, 07:03 PM   #7
retired framer
Rules have really tightened up on that stuff. Today we would be expected to use metal scaffolding from the ground up and then put the board over to the roof.
52Caddy likes this.
figure 7-14
Old 06-17-2020, 07:24 PM   #8
Rewards Points: 4,132
That is supposed to make the house look like it has a steep roof with a shed dormer. I once ripped one off a house and had a smooth wall.
52Caddy likes this.
Old Thomas is offline   Reply With Quote
Old 06-17-2020, 07:28 PM   #9
The chimney is 4 bricks wide plus some... you say that's 18"? Looks like 32'-36" to me.
52Caddy likes this.
Old 06-17-2020, 09:20 PM   #10
Rewards Points: 185
I think you're looking at a different section. I'm talking about the small overhang that still has siding above it.
XSleeper likes this.
Old 06-17-2020, 09:24 PM   #11
Yeah I was looking at the part that is being worked on!
If they still allow wall jacks you could use them on the lower wall if it wasnt styrofoam. But a homeowner can do whatever he wants. Put plywood on the wall and use wall Jacks with ledgerlocks. Or build a temporary scaffold like we would do in the good ol days.
Now that I know what roofline you're talking about, it's still not decorative... it's the way shed dormers are built.
52Caddy likes this.
Old 06-17-2020, 09:34 PM   #12
retired framer
The 18" wide roof that is in the way is just nailed to the side of the wall, decoration.
52Caddy likes this.
figure 7-14
Old 06-17-2020, 09:37 PM   #13
Rewards Points: 185
Actually it's more than decoration. Up in the corner it provides a nice safe place for wasps to build nests!
Old 06-17-2020, 09:39 PM   #14
I guess if you think soffits are purely decorative...
I'd say they are functional.
52Caddy likes this.
Old 06-17-2020, 09:52 PM   #15
retired framer
I am talking about the little one just below the vinyl siding
figure 7-14
