Shed Roof Over Deck Attached To House - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By kwikfishron
  • 1 Post By Nealtw
Old 06-09-2020, 09:06 PM   #1
Rewards Points: 6
Shed roof over deck attached to house
We are wanting to put in a permanent roof over our deck. We have had contractors come out and give us some bids and the lowest is about 10k. The space needing covered is 14’ wide x 16.5’ long. 11’ high at gutter and 7 or 8’ at edge of deck. After getting bids we are thinking of doing it ourselves with help from family and friends . Just wanted opinions on how it would be attached to the house. I was hoping we could get it in under the gutter by removing the soffit. Thanks for opinions and advice.
Shed roof over deck attached to house-29283343-e7ba-4bb3-884a-ca7f1d5b4027_1591754533772.jpg   Shed roof over deck attached to house-f2c2864d-fd59-4f51-83d5-ac48aad1b117_1591754578485.jpg   Shed roof over deck attached to house-864642bb-e2cf-4472-bb7e-3d5a588feb26_1591754620386.jpg   Shed roof over deck attached to house-12e51d67-e4ac-4cd9-9e99-d9202daadecd_1591754714161.jpg   Shed roof over deck attached to house-0e5857db-614f-426a-9056-6181ff3628d7_1591754755099.jpg
Joe MT is offline   Reply With Quote
Old 06-09-2020, 09:23 PM   #2
kwikfishron's Avatar
Rewards Points: 470
Re: Shed roof over deck attached to house
I'd remove the gutter, fascia and soffit and have the new rafters sit on top of the same wall as the upper roof.
Then run the new rafters at whatever pitch you decide and the gutter ends up at the end of the new roof.
The shingles just transition from one pitch to the other.
roofermann likes this.
kwikfishron is offline   Reply With Quote
Old 06-09-2020, 09:27 PM   #3
retired framer
Rewards Points: 15,546
If you and friends are handy and plan well you sure could do it yourself.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-10-2020, 06:15 AM   #4
Rewards Points: 6,136
If you can afford something like this.
Its light weight and can be installed on an existing code compliant deck.
With no need to alter your roof line or house.
Can be installed in one day.
https://www.google.com/shopping/prod...cRvAaoQ8wII2gI
ron45 is online now   Reply With Quote
Old 06-10-2020, 08:27 PM   #5
Rewards Points: 6
@kwikfishron - Sounds exactly what I had in my head. I got another free estimate today which was $15,400 for this to be done, which I'm sure is still worth it. He was going to do the exact same as you suggested. He gave me some structural details that I want to bounce off of you all for my own use in doing this project.
2 - 6X6X12 post set on 3 foot concrete pier footings, with 2 - 2x12 LVL sistered together for the support beam. 2x8 rafters on 16" centers, probably at least 18' long.
Does this sound correct, should I think about adding a 3rd post?
Also, could someone give me and idea (video, picture, drawing) of what the rafters would look like sitting on top of the wall at the house, notched out? some sort of bracket that would be used?
Thank you for your help.
Joe
Old 06-10-2020, 08:29 PM   #6
Rewards Points: 6
@Nealtw ,
Thank for the sketch up. I can picture it in my head, just hope it turns out as good. Thank you for your encouragement.
Joe
Old 06-10-2020, 08:34 PM   #7
Rewards Points: 6
@ron45 ,
We have considered going that direction, just want something a little beefier. And we have struggled to find economical ideas to span the 16-17' to the edge of the deck. Thank you for the idea, it is definitely more economical than the $15,000 dollar bids we have gotten.
Joe
Old 06-10-2020, 09:04 PM   #8
retired framer
Originally Posted by Joe MT View Post
@Nealtw ,
Joe
Jack trusses with extended tops are the way to go .
I have drawn in the house brown, the jack sits in the wall and runs into the roof further up.
The hip roof adds a like problem on that end you would add another angle in red creating another peak on that side.
drtbk4ever likes this.
figure 7-14
