Self Flashing Or Curb Mounted Skylight??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-23-2014, 02:37 PM   #1
Rewards Points: 28
Self Flashing or Curb Mounted Skylight???
I am having a flat roof replaced with a built up (discussed in another post) in a couple of weeks and will be changing out a skylight. I have two roofing contractors. Once swears by a self flashing skylight and the other a curb mounted skylight. I currently have a self flashing skylight, so building a curb to lift it will require some cosmetic work with the interior drywall which is not that big of a deal. But which type of skylight connection would be better for me. Water proofness and ease of working on the skylight are the two top priorities! Any opinions or advise would be appreciated. Thanks.
Hoshwa is offline   Reply With Quote
Old 08-23-2014, 03:43 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,862
Curb if it were my roof with some pitch ripped into the curb.
Old 08-23-2014, 07:28 PM   #3
Metal Roofing
Rewards Points: 658
The curb mounts are my preference.
Done right either works fine, but I think the CM are easier to flash...the skylight is not in your way and you can run your modified highier up the curb. Not to mention replacing them is far quicker and requires no roofing.
AndyWRS is offline   Reply With Quote
Old 08-25-2014, 02:56 PM   #4
Low Slope Roofing
Rewards Points: 114
Curb mount is the only way we will do them. Domed lens or slope the curb.
Also prefer them a good 12" off the surface of the roof.
1985gt is offline   Reply With Quote
Old 08-25-2014, 03:12 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 9,138
On a flat roof...curb.
Like Andy said, you can run the modified up higher. Less places for water to get in.
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Roof patch job ok or not? daluu Roofing/Siding 8 11-07-2012 08:56 AM
Does skylight need replacing? Ttd0715 Roofing/Siding 17 01-14-2012 03:39 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Flashing skylight curbs with architectual shingles PerpetuallyRepairing Roofing/Siding 3 05-30-2009 06:01 AM
