Roofing Material Options For Greenhouse!!! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-01-2015, 12:19 AM   #1
Rewards Points: 6
Question
Roofing material options for greenhouse!!!
I am planning to re-model my greenhouse and switch to different type of roofing material. I used glass cladding before but since it breaks more often than it should, maybe it's time to put a plastic roof?
I heard polycarbonate roof sheets are really good.
Any thoughts on this?
charlesCABP is offline   Reply With Quote
Old 12-01-2015, 02:58 AM   #2
Rewards Points: 6,652
Check with your local glass shops where you live. The problem with Poly, is that the Sun and the heat will bake it and it will end up becoming brittle after a while when exposed to the weather for a long period.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
1985gt (12-03-2015), charlesCABP (12-03-2015)
Old 12-01-2015, 07:37 AM   #3
Rewards Points: 144
Check out Sun Tuff.I don't do greenhouses but have used it on many sun rooms with good results.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
charlesCABP (12-03-2015), gregzoll (12-03-2015)
Old 12-03-2015, 12:44 AM   #4
Rewards Points: 8
Im not quite aware of how the weather in your location is. But in your case, I would say to search more about polycarbonate roofing sheets especially if its your first time to use it. This way, it'll save you time and money. I have no problem using glass on my own greenhouse as its located on warmer and safer place.
arthcamacho is offline   Reply With Quote
Old 12-03-2015, 03:05 AM   #5
There are Poly's that are specifically made for Green House use. http://www.homemadehints.com/greenho...ls-comparison/
http://www.wisegeek.com/what-are-the...house-roof.htm
It all depends on your budget and how much you plan on spending for upkeep and maintenance.
The majority of people that have green houses, end up using them as a hobby for a short period. After a while, they end up turning into storage sheds.
Remember that Green houses are not about the plants. It is about the structure and plants as a whole.
Old 12-04-2015, 12:32 AM   #6
Rewards Points: 8
Hey Charles, try checking these guys: https://www.cabp.co.uk/Roofing-Sheet...ouse-Packs.htm
Tags
cladding materials , glass cladding , polycarbonate sheets , roofing sheets , roofing sheets uk
Beadboard roofing material crhage Building & Construction 0 06-05-2011 08:58 AM
Roofing Material Poopsie Roofing/Siding 6 08-26-2010 03:34 PM
whats the cost for material and labor for TPO roofing mario martinez Off Topic 1 08-12-2010 05:08 PM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 09:10 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
