Roof Valleys Rotting The Trim - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 2 Post By Nealtw
  • 1 Post By DanWDC
  • 2 Post By roofermann
Old 07-31-2020, 10:28 PM   #1
Rewards Points: 6
Roof Valleys rotting the trim
Is there anyway to channel water away from the trim when a roof valley terminates up on the roof? I have a box split level in MN with an attached garage. So imagine 2 boxes jammed together with roof peaks perpendicular to each other with overlapping roofs. Where the roof valleys terminate up high on the roof, the trim is rotting from the water dropping on the roof and splashing up onto the wood trim. The roof valley is the typical 24” valleys I see at the home improvement stores. It’s kind of hard to explain without pictures.
DanWDC is offline   Reply With Quote
Old 07-31-2020, 10:32 PM   #2
Rewards Points: 1,965
Re: Roof Valleys rotting the trim
Typically you would have a gutter on each eve, a deflector at the end of the valley and a downspout or two to control where the water flows.
XSleeper is online now   Reply With Quote
Old 07-31-2020, 11:04 PM   #3
Rewards Points: 6
Here are some pictures. There is no way to get a gutter all the way back, and I can't figure out how to get a rain diverter to capture the water coming down.
Roof Valleys rotting the trim-roof-picture-1.jpg   Roof Valleys rotting the trim-roof-picture-2.jpg   Roof Valleys rotting the trim-roof-picture-3.jpg
Old 07-31-2020, 11:32 PM   #4
retired framer
Rewards Points: 17,006
Cut the shingles and install step flashing under the shingles, cover them with metal flashing tucked under the upper roofing.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 07-31-2020, 11:42 PM   #5
Rewards Points: 6
I'm impressed with your drawing on MY pic. I like that idea a lot. And I have all those parts right now too. I'd be interested if anyone else has any ideas, but Nealtw has a good one.
Nealtw likes this.
Old 08-01-2020, 02:56 AM   #6
roofermann's Avatar
Rewards Points: 749
Wrap the trim in alum. coil stock and never have to worry about painting it again (after installing the flashing)
roofermann is online now   Reply With Quote
The Following User Says Thank You to roofermann For This Useful Post:
DanWDC (08-01-2020)
