Roof Decking/sheathing Cracked On The Inside, Dripping - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-06-2019, 05:07 PM   #1
Rewards Points: 2
roof decking/sheathing cracked on the inside, dripping
Dear gentlemen (and ladies),
i noticed some water dripping from my roof. it occurs at the same time every day, in the late morning after a cold night. this is significant because during heavy rains there is no leak whatsoever. but it drips on warm mornings after cold nights.
after i pulled away the bubble foil and looked at the wood, this is what i found: cracks and some mold, a little water damage.
gentlemen, how do i repair this problem? i did not attach pictures of the outside roof shingles because everything there looks good and there is no leak when it rains.
thanks for your time and i will be happy to post additional pictures if anyone requires more information.
roof decking/sheathing cracked on the inside, dripping-img_0343.jpg   roof decking/sheathing cracked on the inside, dripping-img_0345.jpg   roof decking/sheathing cracked on the inside, dripping-img_0354.jpg
bamboozle is offline   Reply With Quote
Old 01-06-2019, 05:25 PM   #2
retired framer
Rewards Points: 5,628
Re: roof decking/sheathing cracked on the inside, dripping
Worm moist air from the house is coming into contact with a cold surface.
Seal the ceiling to stop moist air and insulation and venting to keep both sides of the sheeting at outside temperature.
Old 01-06-2019, 07:33 PM   #3
Rewards Points: 8,030
Hi Bamboozie and welcome to the forum.
As Neal said, you have a condensation issue that is forming frost or ice and melting with the early morning warmer tamps.
We need a full description of your ceiling from the inside ceiling surfact to the shingles on top.
What is your climate region, nearest large city?
What is up there for insulation?
What do you have for ventilation?
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Tags
decking , drip , leak , roof , sheathing
GAF TPO? Should whole roof be stripped? leeleses Roofing/Siding 9 06-18-2018 07:25 AM
Asphalt/reflective roof coating. Is my roof a suitable candidate? Pics inside. anonymoususer Roofing/Siding 5 12-05-2010 06:33 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
