Removing Fiber Cement Siding For Insulation Install - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Colbyt
Old 08-10-2017, 12:47 PM   #1
Rewards Points: 8
Removing fiber cement siding for insulation install
Hey everyone. We recently purchased a 116 year old farmhouse and one of the things I need to do before winter is insulate the walls. There is no insulation in them right now. So I have an insulation contractor coming to blow cellulose inside the wall cavities.
We determined going in from the outside would be the easiest based on the construction. The exterior of the house is covered in cement board lap siding. I need to remove 2 courses of siding on each floor (below the windows and above), so we can drill into the wall cavities.
My question is how is the best way to remove the siding and nails and how to replace it. I can face nail it back on but you will see all those nails if I do.
coleathornton is offline   Reply With Quote
Old 08-10-2017, 02:57 PM   #2
Rewards Points: 8,695
Re: Removing fiber cement siding for insulation install
Depending on what they nailed it with you will mostly be unable to remove it without destroying it. It tends to break at the nail heads. If they installed it with roofing nails you may be able to work them out.
Face nailed with the proper siding nails you will will never see the nails once it is painted. If it is the colored kind you will and if new boards are needed they most likely won't match the existing ones.
I guess I am saying that drywall or plaster repairs might be easier.
Houses that old often had bracing boards between the studs so you may not wind up with a fully insulated wall.
Nealtw likes this.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 08-10-2017, 03:07 PM   #3
retired framer
Rewards Points: 15,596
You might be able to get a hacksaw blade between the siding and the sheeting behind to cut the nail.
https://www.thingiverse.com/thing:2242444
Nealtw is offline   Reply With Quote
Tags
cement siding , hardy backerboard , insulation upgrade , siding
Vinyl or Fiber Cement Board Siding? vivix Roofing/Siding 20 07-17-2015 03:20 PM
Gable ends and fiber cement siding Daugela Roofing/Siding 8 12-25-2014 08:00 AM
fiber cement siding decisions wendl Roofing/Siding 1 09-01-2011 06:52 AM
Proper way to flash exisiting windows when installing new fiber cement siding, plus.. deminimis Carpentry 8 09-23-2010 09:55 PM
House Wrap - removing vinyl siding to install wrap roo747 Building & Construction 9 11-01-2007 05:27 PM
