Remaining Life On This Rolled Roofing Portion On Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By craig11152
Old 10-27-2016, 12:20 AM   #1
Rewards Points: 378
remaining life on this rolled roofing portion on roof?
Hope I can still get some use out of it before replacement. The red bits along the center are the granules from the red shingles. There's a few places with small cracks on the top layer of the rolled roofing.
daluu is offline   Reply With Quote
Old 10-27-2016, 07:36 AM   #2
Rewards Points: 17,808
Re: remaining life on this rolled roofing portion on roof?
Looks like a dead valley from that picture.
Needs to be removed and replaced ASAP, not just patched up.
http://www.graceprosintheknow.com/dead-valley-roof/
daluu (10-27-2016)
Old 10-27-2016, 07:44 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,350
Some granule loss is normal over the life of the shingle. What is not recommended is that valley design from a function standpoint.
I am going to bet you are going to have leaks along that run and re-doing that valley in metal might not be a terrible idea.
joecaption likes this.
The Following User Says Thank You to Windows on Wash For This Useful Post:
daluu (10-27-2016)
Old 10-27-2016, 09:50 AM   #4
craig11152's Avatar
Rewards Points: 1,180
I'm guessing that is an SBS Modified not a #90 roll?
If its an SBS how long has it been in place?
In a situation like that I would give an SBS Modifed 10-20 years and a #90 1-5 years. A world of difference.
Don't look at me. I didn't vote for either one of them.
craig11152 is online now   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
daluu (10-27-2016)
Old 10-27-2016, 10:51 AM   #5
Rewards Points: 378
That has been in place / installed for 2 yrs. I think it is SBS but will check with my roofer who installed it.
Old 10-27-2016, 03:14 PM   #6
Rewards Points: 378
Originally Posted by joecaption View Post
Looking at the linked site's comments section, looks like some folks recommend building a cricket over the dead valley, then shingle & flash over that? something like this?:
or is my valley too short and/or not steep/deep enough for such a cricket?
Old 10-27-2016, 03:30 PM   #7
That would have been a far better way to do it.
Old 10-30-2016, 11:27 PM   #8
Rewards Points: 378
By the way, here's a closeup of one area of that valley.
Old 10-31-2016, 05:53 AM   #9
craig11152's Avatar
That picture almost looks like the shingles are running under not over that valley.
and is that "crack" in the middle a material crack or some crusted on debris?
Windows on Wash likes this.
Old 10-31-2016, 07:23 AM   #10
+1 The picture is weird like @craig11152 said. Looks like the shingles are under.
Old 10-31-2016, 11:59 AM   #11
Rewards Points: 378
Somehow that photo came out weird when I got a close up or zoomed in on my iPhone. (iPhone camera problem?) The shingles are actually over that. It looks proper on the zoomed out overall photo.
And there's 2 layers of that as well, overlapped. One layer for each of the intersecting roofs. We only see the top layer here.
As for the crack, it seemed to be deterioration of the material instead of caked dirt on top. The material is thinning out with loss of granules where some water ponds.
Presidential shingles for long life on 3/12 pitch roof in Olympia, WA. vettespeed Roofing/Siding 5 09-08-2015 08:16 AM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Built Up Roofing (BUR) vs Modified Bitumen Roof (Torch Down) RacerX Roofing/Siding 4 01-31-2010 01:54 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
