Rake Board Repair - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By dealhunter999
Old 06-29-2020, 12:40 PM   #1
Rewards Points: 8
Rake board repair
Hi Friends,
I live in a town home (3-story). I need to repair/paint rake board shown in the picture.
I am uncertain if this needs replacement or repair. Also, as shown in the picture, room trim needs fix. So, I am trying to be as informed as possible before making final decision and hiring contractor.
One of the contractors recommended PVC replacement, costing $650 )(labor+material+paint)!
I would like your expert opinion on following:
  1. What is a typical cost for replacement and/or repair for such task? I live in northern Virginia.$650 sound very high.
  2. Is PVC rake board better than wood?
  3. Is there anything else I should be aware of?
  4. Thanks for reading!
RJ
dealhunter999 is offline   Reply With Quote
Old 06-29-2020, 12:52 PM   #2
retired framer
Rewards Points: 15,542
Re: Rake board repair
That looks like a sad repair already, It looks like metal without enough support for the shingles.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
dealhunter999 (06-29-2020)
Old 06-29-2020, 01:01 PM   #3
Rewards Points: 8
In your opinion what sort of repair is needed? I am very inexperienced in this area.
Old 06-29-2020, 02:45 PM   #4
retired framer
I think we need a picture closer up and identify what is there and what is the material that looks to be falling out.
figure 7-14
Old 06-29-2020, 03:45 PM   #5
Rewards Points: 790
Yes, need a better picture. But, PVC would be better than wood. PVC doesn't really need to be painted if you're ok with the color of the PVC. It is very easy to paint with latex. Initially the price jumped out at me but then I went back and saw it was 3 stories up.....that in itself would increase the cost. How about getting a couple of more estimates?
JIMMIEM is offline   Reply With Quote
Old 06-29-2020, 07:51 PM   #6
Hi Friends,
RJ
You better take him up on that $650 repair. I wouldn't touch it without a full roof replacement contract attached to it.
Sent from my motorola razr using Tapatalk
A&E Exteriors is offline   Reply With Quote
Old 07-02-2020, 01:04 PM   #7
Rewards Points: 8
Thanks everyone. As it turns out only trim needed replacement , rake board is fine. Rake board replacement is around 1500-2500 (if shingle needs replacement too). This ha been valuable experience as I finally learned something
Nealtw likes this.
