Open Or Closed Valley - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-13-2015, 07:02 PM   #1
Rewards Points: 24
Open or closed valley
I'll be be roofing my house soon and thought I ask what everyones opinion on a closed or open valley. I like the way the open valley looks but is it better than a closed and how will it hold up? Some say its a little more work. I also was thinking about using copper in the valley instead of aluminum over the ice /water barrier if I decide to go open valley.
I also hear some say that nailing the shingles on a closed valley would put the nails near the center of the valley, which would cause it to leak. Im using architectural/dimensional shingles if that makes a any difference.
Just thought I ask. Thanks John
kmegk9unit is offline   Reply With Quote
Old 05-13-2015, 07:21 PM   #2
Rewards Points: 18,382
Installed right a woven valley is far better.
Done right there's 0 reason for any nails to be any closer then 6" of the valley.
Architectural shingle by far are the easiest to cut so there's no seam at the valley.
The Following 5 Users Say Thank You to joecaption For This Useful Post:
kmegk9unit (06-24-2015), mae-ling (08-25-2015), roofermann (05-14-2015), Windows on Wash (05-14-2015), Yodaman (05-13-2015)
Old 05-13-2015, 07:44 PM   #3
Property Mgt/Maint
Rewards Points: 7,614
Putting the weave in the valley also puts more asphalt in the valley.
A veteran roofer once told me never to put metal down first in the valley because it will cook the asphalt. Not sure if its true or not but I only use Ice & water in the valley under the weaved asphalt shingles.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 05-14-2015, 03:11 PM   #4
Rewards Points: 850
woven is better, but cutting the high side looks better. as for wear in the valley, ive as of yet replaced a shingle roof just because its leaking in the valley. more often than not it because there blowing off or just worn out.
hotrod351 is offline   Reply With Quote
The Following 2 Users Say Thank You to hotrod351 For This Useful Post:
Old 05-14-2015, 05:10 PM   #5
Property Mgt/Maint
IMHO - its a matter of preference which looks better, personally I like the weave because I know its the mark of a quality job.
I have a valley right now that is in need of emergency tar, hoping to buy me another year or two. It is a open, rolled roofing laid over metal construction. Not 100% on the metal but everyone I have ever torn off like this had metal under it.
Old 05-14-2015, 05:46 PM   #6
Davejss's Avatar
Rewards Points: 1,028
I've done both several times. I prefer a woven vally. To my eye it looks better, and it's a bit easier to install. I've also done several cut valleys where one side is run up like it's woven and the other side is cut. That is my prefered method for tight valleys such as on dormers. The cut valleys tend to lay flatter in a tight area.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
Old 05-15-2015, 01:13 PM   #7
Rewards Points: 1,120
Woven valleys look rough on laminated shingles. In my climate, I like to use open metal. We usually use 24ga steel, installed properly they outlast the shingles.
We do closed cut valleys on bastard pitchs, running the lower pitch under the steeper.
PatChap is offline   Reply With Quote
The Following 3 Users Say Thank You to PatChap For This Useful Post:
kmegk9unit (06-24-2015), mae-ling (08-25-2015), Windows on Wash (05-15-2015)
Old 05-15-2015, 01:45 PM   #8
Rewards Points: 850
A veteran roofer once told me never to put metal down first in the valley because it will cook the asphalt, was also told the same thing many many years ago. you cut the high side because you get more force from the water running down it. anyway ive always cut them. you run metal then how far back do you cut them from the center, depends on trees and how much other stuff your going to get in there. the wider the easier it is to clean out. i do believe the bundles have instructions on them. found a site that compaires all ways of doing it but wasnt able to attach the link.
The Following User Says Thank You to hotrod351 For This Useful Post:
Old 05-23-2015, 09:31 PM   #9
Rewards Points: 18
Yeah.. Metal W-Valley is waaayyyy better. Just use 30lb felt or better underneath, and make sure you have the paper from the deck felt going over the metal by about 6". Then run a row of shingles parallel with the the valley, 2" away from it, after that just cut all courses square so the bottom corner stops at the edge of the valley starter. I don't like closed valleys because the shingles don't lay flat, as soon as they go through a season they get brittle, next thing you know the kid cleaning your gutters out steps in the valley and there is a huge hole there. Would never happen with metal. Also it provides a better channel for debris to be carried off the roof.
matt_604 is offline   Reply With Quote
The Following User Says Thank You to matt_604 For This Useful Post:
Old 06-24-2015, 04:50 PM   #10
Rewards Points: 24
Thank You everyone. It made my decision easier to make on what to do with the valley. I will post pic's of the roof when we get it done.
Thank You Very Much>
Old 06-24-2015, 05:27 PM   #11
craig11152's Avatar
Rewards Points: 1,220
don't hold us in suspense....which way are you going?
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
kmegk9unit (08-24-2015)
Old 06-24-2015, 05:34 PM   #12
craig11152's Avatar
I'm late to the party...too late.... but a copper valley has somewhere between a 300 year and a 2000 year life span. Hard to beat that with a shingle valley, close cut or woven.
Old 06-24-2015, 05:40 PM   #13
craig11152's Avatar
when I first started roofing in 1979 most of our valleys were galvanized metal preformed. Eventually we started bending our own out of aluminum picking colors to compliment shingles. When laminated shingles took over the market we switched to a close cut valley for most of our work. I never did a woven valley and you never much see them in SE Michigan. Maybe its a regional thing.
Old 08-24-2015, 10:07 PM   #14
Rewards Points: 24
Never started roof. I had to go and finish my daughters roof.
Old 08-24-2015, 10:21 PM   #15
Rewards Points: 24
Not Late
Never started roof. Had to go finish my daughters roof someone screwd up. I decided to go with a close cut. One question is, if you have to nail and you cant nail in that 6" margin what do you do? Thats the part that puzzles me.
Im doing a bathroom remodel and helping a family member with a deck at this moment . Hitting the roof next year.
Should my gable end vent that is adjustable stay open or closed for the winter? Deck Insulation 4 11-25-2013 05:15 PM
Open Valley - Starter Strip Ciskman Roofing/Siding 13 04-09-2012 08:06 PM
Converting a closed porch to an open porch taycop Building & Construction 2 07-28-2011 11:13 AM
open vs closed valley KarlJay Roofing/Siding 1 09-19-2010 07:58 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
