A New Roof Half Vaulted, Half Regular Ceiling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Nealtw
Old 01-18-2019, 01:45 PM   #1
Rewards Points: 6
A new roof half vaulted, half regular ceiling
Hello! For a new roof install, half vaulted, no drywall, just exposed beam and rafters. The other half will have 8 ft ceilings, conventional rafter framing. Would it be a good idea either economically or structurally to have a glulam ridgebeam for the vaulted part and a smaller sawn lumber ridgebeam for the part with the ceiling? Horizontal plane is 48' x 36'.
Tblepp is offline   Reply With Quote
Old 01-18-2019, 02:15 PM   #2
retired framer
Rewards Points: 15,110
Re: A new roof half vaulted, half regular ceiling
Depending what exactly you are after, for the ceiling area I would use trusses, a girder truss can be made to hang the beam for the vaulted ceiling. But you could also look at scissor trusses for the vault too.
Bud9051 likes this.
Tags
beam , ceiling , glulam , ridge beam , vaulted
Crown into vaulted ceiling BlueBSH Carpentry 7 12-31-2018 11:20 AM
Half vaulted ceiling with 2x6 rafters on 16 OC vestaviascott Building & Construction 9 04-21-2015 08:28 AM
Miami Vaulted Ceiling Insulation (need to seal?) ShenAmateur Insulation 4 08-06-2014 01:21 PM
HELP! lighting question for vaulted ceiling pauls General DIY Discussions 5 07-03-2010 04:53 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
