Are My Shingles Okay? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-21-2016, 10:19 AM   #1
Rewards Points: 1,052
Are my shingles okay?
We are having a vicious winter storm; yesterday there were gusts over 50mph. A neighbor tells me a previous owner lost shingles in a storm, so I am a bit anxious about these things.
Every thing looks fine, except the corner shingles shown in the attached photo. They look up lifted a bit.
Anything to be concerned about?
How are these corners held down?
Thanks.
Toller is offline   Reply With Quote
Old 11-21-2016, 10:32 AM   #2
craig11152's Avatar
Rewards Points: 1,216
Re: Are my shingles okay?
Do you know if those are actual cap accessory shingles or perhaps 3-tabs cut?
In theory they do have a seal but on cap sometimes that seal never fully engages. Another problem with cap is they can get nailed too high and that doesn't help,especially if they don't seal well.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 11-21-2016, 11:12 AM   #3
I don't know what they are; I bought a 6 year old house 4 years ago.
I was hoping you could tell from the photo.
Old 11-21-2016, 12:07 PM   #4
craig11152's Avatar
My question wasn't all that key to any answer. More a bit of curiosity. But I think they may be 3-tab's cut in thirds based on the overall length.
If the shingles are at least 10 years old and nothing has blown off yet I would not lose any sleep over it. They probebly never fully sealed which is not uncommon for cap bent over a hip or ridge. If its a walkable pitch and you get high wind regularly I suppose you could manually seal them with some mastic.
Old 11-21-2016, 01:25 PM   #5
Rewards Points: 17,890
3, Tabs used as caps are 1/2 as thick has real cap shingles.
If it's only a single layer, it's a cut 3 tab.
They also cost about twice as much so sometimes people cheap out.
A 3 tab is far more likely to lift up and crack.
Old 11-21-2016, 06:29 PM   #6
Rewards Points: 1,048
Those are IKO, the caps are 3tabs. They look like they need some attention, nails might be blown through.
PatChap is online now   Reply With Quote
Old 11-23-2016, 04:39 AM   #7
Rewards Points: 2,452
Not sure if osi quad will cure in cold but read the small prints. Silicon I think will cure. Quarter size bead and stick it back. If necessary, drive a screw and cover with caulk. Silicon is the last thing I would use since it's sensitive about the surfaces but if it works in these temps, use it.
carpdad is offline   Reply With Quote
Old 11-23-2016, 07:36 AM   #8
Rewards Points: 692
Get a tube of Black Jack Roofing Cement to stick down the shingle edges.
JIMMIEM is offline   Reply With Quote
Old 11-25-2016, 10:48 AM   #9
Attached is a photo of the area. It is very steep and very high. I am not going up there.
Could a handyman do this, or is a job for a roofer?
Can it wait until spring? What are the consequences of a problem now? Look bad; roof leak; house failure?
Old 11-25-2016, 12:27 PM   #10
Rewards Points: 692
Whoever does it make sure they are insured!!!! A knowledgeable handyman could do it but handymen are not all created equal. A professional roofer for sure could handle it. Depending on how the roofing was done would/could be important if shingles start to get blown off....just losing one shingle could start a chain reaction and result in losing a lot more shingles. Water damage is always a possibility. Best to have a reputable roofer look at it ASAP.....'stitch in time'.
Roofing shingles all overlap but what type do I choose? Marrah Ferr Roofing/Siding 8 11-13-2015 05:49 AM
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Manufactures date on 3 tab shingles frankm1960 Roofing/Siding 2 08-15-2013 07:27 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
