Misaligned Roof Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By Bud9051
  • 2 Post By craig11152
Old 05-14-2018, 11:31 AM   #1
Rewards Points: 2
Hi there!
My wife and I are building a 10'x16' storage shed. We've put up all of the siding, roof rafters, and we are on to the roof sheathing now. Our floors are square, our walls are square, and everything up to this point has gone rather smoothly, but when we started to install the roof sheathing, there are some points where the plywood is wavy. Turns out, the roof rafters are slightly misaligned left to right.
while putting up the rafters, I drew a line from one end to the other, so that I could see if everything was aligned, and it appeared to me that they were (Note: Most of the time, I'm building this shed alone, and I put op the rafters alone too!).
I know structurally, it is sound, but I want to correct the waviness, without having to redo the rafters. I've read that shims can be used and even a portable planer to shave away the sections of the rafters that stick out (note the rafter are 2x6s, so there's plenty of thickness to spare, so to speak.
In case anyone is wondering, some of the more egregious misalignment is in upwards of 1/2 - 3/4 of an inch, but it's enough to notice the waviness in the plywood.
Has anyone run into this before? Please offer some suggestions.
prullan is offline   Reply With Quote
Old 05-14-2018, 11:45 AM   #2
Rewards Points: 6,452
Re: Misaligned Roof Rafters
Waviness implies "up and down" where square is different. Up and down should have been noticed when you "crowned" each rafter. Checking the crown puts all variations in the up direction and removes any that are extreme.
At this point you need to identify the worst and modify them or replace them.
Pictures if you can?
Bud
craig11152 likes this.
Bud9051 is online now   Reply With Quote
Old 05-14-2018, 11:57 AM   #3
craig11152's Avatar
Rewards Points: 1,220
I agree with Bud it sounds like a crowning issue.
I wold stretch a string across them shimmed up at each end and figure out which ones are the worst and replace them.
How many are there? shims and a planer seem like more work than a cats paw and pry bar.
roofermann and Nealtw like this.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 05-16-2018, 04:28 AM   #4
Rewards Points: 2,778
Depends on the size of the roof but cutting away 3/4" of the lumber can compromise its capacity. Esp with snow load. Check your rafter spans. Also not sure how green lumber will respond with that much cut. I may be over thinking, but ripping a lumber can make it bend/twist just as much.
You can only try. If cutting, I suggest a planer. Using a saw at that angle and space (in the rafter bays) needs some experience with that specific cut. Binding blade is common but always scary. Saw runs away from you.
carpdad is offline   Reply With Quote
Tags
rafters , roof , sheathing , trusses
A-frame roof to flat roof connection "slippage" miamicuse Building & Construction 11 10-01-2016 09:01 PM
Integrity of roof rafters williams_run Roofing/Siding 4 06-10-2015 06:41 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 12:06 PM
