Metal Roofing Vs. More Traditional Forms - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By craig11152
  • 1 Post By Windows on Wash
Old 10-04-2016, 04:37 PM   #1
Rewards Points: 2
Metal roofing vs. more traditional forms
So in your opinion, what are the benefits/disadvantages of a metal roof over other traditional materials?
BournemouthRoof is offline   Reply With Quote
Old 10-05-2016, 05:12 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,372
Re: Metal roofing vs. more traditional forms
No disadvantages except expense.
They are all benefits. Longevity, heat reflection, aesthetics, potable run-off, durability, wind resistance, etc.
Old 10-05-2016, 05:27 AM   #3
craig11152's Avatar
Rewards Points: 1,188
what sort of metal roof? I am not a big fan of the style that has exposed fasteners. We have one on my Church and I track down leaks on a yearly bases mostly from failed washers.
joecaption likes this.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 10-05-2016, 06:19 AM   #4
Agreed.
Should have made that distinction @craig11152 . You are 100% correct in that exposed fastener roofs are a no-go in my opinion.
Old 10-05-2016, 06:39 AM   #5
Rewards Points: 1,466
Check with your insurance provider for their opinion also. You may experience a change in the premium.
Old 10-05-2016, 06:28 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 1,764
If you are in an area or snow accumulation you should consider the dams or fixtures - sorry I don't know what they are called - to prevent avalanches of snow sliding off. I have heard of the insurance issue but have no idea what it is based on.
The only negative comment I have ever heard is firefighters don't like them because they can be more difficult to vent in the event of a house fire - but then again I know a number of firefighters that have them on their houses, so go figure.
lenaitch is offline   Reply With Quote
Old 10-05-2016, 09:06 PM   #7
Rewards Points: 850
they last forever, they dont blow off, water sheets off them. where i live a metal roof is 50% again as much as shingles, but well worth it.
hotrod351 is offline   Reply With Quote
Old 10-05-2016, 09:18 PM   #8
Snow birds, snow fencing, snow retention, etc.
If the snow is heavy enough, look into heated wire applications as well.
Very true about getting into them. I have also seen them choke out a fire and they are a must in a heavy lightning and wildfire area.
+1
Even more in these parts.
lenaitch likes this.
metal roofing on 1:12 pitch browneyedsusie1 Roofing/Siding 14 09-05-2014 08:02 AM
Can I use metal J-channel and drip caps intended for roofing as my casing beads? iLikeDirt Windows and Doors 1 09-03-2014 12:53 PM
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Cheap metal roofing solution? ligyron Building & Construction 2 08-10-2011 06:28 PM
