Metal Roof Creases Sanity Check - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree9Likes
  • 1 Post By nobbyv
  • 1 Post By Nealtw
  • 1 Post By roofermann
  • 1 Post By PatChap
  • 3 Post By nobbyv
  • 2 Post By Nealtw
Old 01-04-2019, 07:46 PM   #1
Rewards Points: 282
I know this is the DIY Chatroom, but I could use a sanity check here with a contractor job: I hired a roofing company to install a standing seam metal roof on the house I'm building for myself. It's NOT an easy job: the roof is VERY cut up, and a good size (3000 sq ft house w/ attached 1700 sq ft garage). I got 5-6 estimates, and these guys had an impressive portfolio/references, and came in with a bid that was attractive (not lowest, but bottom third). They bend basically everything on site with a $85k rig from coils of the metal finished in the color we special ordered.
We are into week 6(!) of this job, and they are finally close to finishing. Side note: a few weeks ago, they had 6-8 long (16-20') panels they had run that they ended up leaving lying on the ground. They explained they were "too short" for the section they were working on.
Today, the 6-8 "mistake" panels were gone (I had to be at the office so wasn't there to see it), and a back section of the roof is complete. However, many of the panels there have what appear to be creases at various spots. These aren't "waves" or anything like that, I'm talking what appear to be 1-2' areas across the width of the panel that appear darker than the rest of the panels. Some have one crease, some two, some none. I assume what happened is they decided to re-use these "mistake" pieces, and over the course of the previous 3-4 weeks of laying on the ground with multiple contractors around, the "mistake" pieces had acquired the creases, and they put them up anyway instead of running new panels.
I know these guys underbid the job. The foreman has basically told me as such. They originally anticipated three weeks to complete, and as I mentioned we're on week six. They just want to be done with it and get on to the next job.
But I'll see these creases every time I look up. None of the other sections have these creases. I plan to request they replace them, but wanted to be sure I wasn't being out of line. I know the creases don't affect the performance of the roof, but we're paying good money for this roof, and I want to be sure I'm not out of line expecting that the roof panels not have this "creased" look.
roofermann likes this.
nobbyv is offline   Reply With Quote
Old 01-04-2019, 07:53 PM   #2
retired framer
Rewards Points: 4,236
Re: Metal Roof Creases Sanity Check
If they were the short pieces, they should have protected them until they were needed.
MTN REMODEL LLC likes this.
Old 01-05-2019, 07:03 AM   #3
roofermann's Avatar
Rewards Points: 721
Can you post some pics please?
roofermann is online now   Reply With Quote
Old 01-05-2019, 06:19 PM   #4
Rewards Points: 282
Rained all day today, and I need sunlight to see the creases. I'll grab a pic tomorrow.
The Following User Says Thank You to nobbyv For This Useful Post:
roofermann (01-05-2019)
Old 01-06-2019, 04:46 PM   #5
Rewards Points: 282
It's tough to pick them up w/ a camera, but here's an example: you can see one on the panel one over from the chimney, two on the fourth panel, and one more on the seventh panel (that one's pretty small). It's tough to see in the second pic, but there are two on adjacent panels.
Am I out of line thinking this isn't right? There are longer panels elsewhere that all look perfect.
Metal Roof Creases Sanity Check-img_1389.jpg   Metal Roof Creases Sanity Check-img_1388.jpg
Old 01-06-2019, 05:16 PM   #6
roofermann's Avatar
Rewards Points: 721
Called "oil canning", not much to be done about it.
Windows on Wash likes this.
The Following 2 Users Say Thank You to roofermann For This Useful Post:
nobbyv (01-06-2019), PatChap (01-06-2019)
Old 01-06-2019, 05:23 PM   #7
Rewards Points: 1,110
Flat panels will always have some degree of oil canning.
Striated panels might have helped, but a little crease near the valley isn't unreasonable, and is a sign they did a professional install.
PatChap is offline   Reply With Quote
The Following User Says Thank You to PatChap For This Useful Post:
nobbyv (01-06-2019)
Old 01-06-2019, 05:36 PM   #8
Rewards Points: 282
Thanks for talking me down off the ledge, guys!
Old 01-06-2019, 08:39 PM   #9
retired framer
Give it six month and you will quit looking at it.
Old 01-07-2019, 06:49 AM   #10
retired painter
Rewards Points: 1,340
Very true! right now the roof is your main focus, once you move onto something else it will become a distant memory .... and it's not like it's a defect that will always jump out and grab your attention.
mark sr is offline   Reply With Quote
Repairing leaky metal roof gadolphus General DIY Discussions 5 12-20-2017 06:56 AM
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 04:18 PM
Not venting a metal roof. maestro Building & Construction 16 12-13-2011 03:31 AM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
Metal Roof Repair Questions [email protected] Roofing/Siding 3 09-17-2008 11:00 PM
