Looking For Exterior Cladding Ideas For A Garage - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 06-10-2019, 11:41 AM   #1
Rewards Points: 310
Looking for exterior cladding ideas for a garage
I'm looking for some ideas for to cover the block on this garage in a way to compliments the house to which it is attached.
Note that I am removing the eaves and crappy half done siding of the garage. A roof top deck will be be built on top of the garage, so one can step out of the kitchen door (pictured) and walk out on to the deck at some point in the future.
Also pictured is what the place looks like from the front. The home's siding will be blue and corner posts white, as shown on the dormer in the 2nd photo.
Fisher1871 is offline   Reply With Quote
Old 06-10-2019, 12:19 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 434
Re: Looking for exterior cladding ideas for a garage
Cement parging (think stucco) with a coordinating color.
Sent from my Moto E (4) Plus using Tapatalk
Fisher1871 likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Fisher1871 (06-10-2019)
Old 06-10-2019, 01:03 PM   #3
Rewards Points: 310
In your opinion, is that something a DIYer can do?
Old 06-10-2019, 01:59 PM   #4
retired framer
Rewards Points: 14,748
I would build the deck first then see what would complement that.
Do not use flat bottom gables with scissor trusses.
Old 06-10-2019, 02:20 PM   #5
Rewards Points: 310
The deck is probably going to be a few years off. It's a major undertaking. I have the replace the roof of the garage with engineered I joists (due to snow load and span), new decking, put down a rubber roof, and then build a floating deck on top.
Old 06-10-2019, 02:25 PM   #6
retired framer
We do a roof rated solid vinyl deck that lasts 25 - 30 years.
I think you could strap the building and match the house with siding.
Fisher1871 and ktownskier like this.
Old 06-10-2019, 02:31 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 434
A DIYer could do but I would not try as a first timer. Maybe try on a back wall and see if you like results. It will require 2 coats to cover the joints and give a smooth finish. The cement dye comes as powder, mix a small batch and let cure to see the final color.
Sent from my RCT6213W22 using Tapatalk
Old 06-11-2019, 08:05 AM   #8
Rewards Points: 310
Does one take the parging below ground level?
Old 06-11-2019, 08:20 AM   #9
Rewards Points: 1,489
When you say "deck" do you mean something that will allow water to go down into the garage?
huesmann is offline   Reply With Quote
Old 06-11-2019, 08:31 AM   #10
Rewards Points: 2,670
The Parging / Stucco should not be more than 6 inches below grade.
As for a DIY project your end results would look very bad. It would require at least two persons that know a little about applying a cement product to a CMU wall.
ClarenceBauer is online now   Reply With Quote
The Following User Says Thank You to ClarenceBauer For This Useful Post:
Fisher1871 (06-11-2019)
Old 06-11-2019, 11:39 AM   #11
Rewards Points: 716
I agree with Neal, strap the building and put the same siding as the house and paint it the same color or complimentary color. Just make sure to keep it above grade.
You can put parge below that. Or put in brick or stone veneer.
Just anything but the gosh darn block.
I know a little bit about a lot of things. What I don't know, I research.
The only stupid question is the one you DON'T ask!
Most of all, have fun! It ticks people off and ruins their day.
As a technical writer, I tend to be lengthy in my responses as I want to be accurate.
ktownskier is online now   Reply With Quote
The Following User Says Thank You to ktownskier For This Useful Post:
Old 06-11-2019, 12:26 PM   #12
Rewards Points: 310
It's going to end up being a rental. I'm somewhat considering just painting the block and moving on.
If I go to sell it, put something nicer on.
Old 06-11-2019, 12:32 PM   #13
Rewards Points: 310
No.
Replace current roof framing and decking (city engineer requirement for the planned roof top deck), put down rubber roofing, then a roof top deck/railing on sleepers (running with the slope).
Old 06-11-2019, 12:48 PM   #14
retired framer
The Following User Says Thank You to Nealtw For This Useful Post:
Old 06-11-2019, 01:21 PM   #15
Rewards Points: 310
I like this!
