Insulated Siding Options. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Bud9051
  • 1 Post By stick\shift
Old 01-19-2019, 10:46 AM   #1
Rewards Points: 527
Planning to have new siding installed and windows replaced. Most everyone in my neighborhood put vinyl siding over the old "asbestos" shingles. I'd like to add some R value to the walls with the siding and wrap. I've read about the limit increase with "insulated" vinyl siding. And I've read the insulated vinyl siding isn't really insulated. Is there a worthwhile siding product that will increase R value?
I don't want to get into a huge project that involves adding foam board because the front of my house is 1/2 brick and front windows are newish. Those windows won't be replaced.
Also, are costs associated with installing insulated siding tax deductable like installing new windows.
LarryJ-nova is offline   Reply With Quote
Old 01-19-2019, 01:09 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 14,406
Re: Insulated Siding Options.
It doesn't increase R-Value and it does create a decent thermal break. As much as the marketing materials would like you to believe...probably not.
Best one out there, in my experience, is the Prodigy from Alside.
What kind of asbestos siding to you have? Is it transite?
You probably maxed out your deduction on other stuff at this point, but it can't hurt to check with the accountant.
Old 01-19-2019, 02:51 PM   #3
Rewards Points: 527
Thanks for the recommendation on Alside. Watched a few videos. Looks promising.
Haven't tested the shingles, just assume they're asbestos based on what everyone says. Regs allow me to remove and dispose in landfill myself, but contractor has to abide by abatement rules. Contractor says they install vinyl siding on top of the shingles.
Old 01-19-2019, 02:56 PM   #4
retired framer
Rewards Points: 17,010
There are insurance companies using it for an excuse to not cover the house.
Old 01-19-2019, 03:11 PM   #5
Rewards Points: 527
Not following you, Neal. There's not an insurance company involved here. Just a home upgrade, not a claim.
Old 01-19-2019, 03:50 PM   #6
Rewards Points: 3,206
I don't have specifics but dealing with the removal today will probably be far less expensive than a few years down the road. Prospective buyers will have objections to absorbing the risk of owning your siding.
I have stripped old siding off of a few homes (not related to asbestos) and it is perhaps the easiest part of the job. You might work with the siding contractor and you remove and dispose of the old while they take over and install the new. With the old gone you will have some extra depth and a nice flat surface to install a well sealed layer of rigid. 1/2" would match the siding you removed and although still not a lot being taped and sealed it would be a plus.
With the old siding off your window replacements could be new construction with some trim work inside. But a much better installation, new flashing and an opportunity to deal with the gap around the window.
Bud
Nealtw likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 01-19-2019, 04:02 PM   #7
retired framer
http://www.farmersinsurancegroupsuck...ead.php?3,1844
Old 01-19-2019, 04:44 PM   #8
Rewards Points: 4,840
Vinyl siding, by design, is installed loosely and allows lots of air to flow through the cracks and joints. Best is to insulate and then install normal vinyl.
Nealtw likes this.
stick\shift is offline   Reply With Quote
Old 01-19-2019, 10:42 PM   #9
While they aren't supposed to be nailed tight so as to accommodate expansion, the foam backed products sit as flush as the wall is (i.e. condition of exterior wall sensitive here).
If the walls are pretty true, there isn't much air moving behind the siding and they R-Value does translate as an increment relative to its intimate contact with the structure.
Siding right on studs? Davef_dci Carpentry 6 03-07-2013 05:31 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
