Ideas On Avoiding This Gutter Through The Deck - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 2 Post By Fix'n it
  • 1 Post By roofermann
  • 1 Post By craig11152
Old 08-17-2018, 10:51 PM   #1
Rewards Points: 2
Ideas on avoiding this gutter through the deck
Ideas on avoiding this gutter through the deck-gutter-through-deck.jpgIdeas on avoiding this gutter through the deck-img_2673.png
Hi. The first is an old picture. At this point, I'm planning to replace the decking with LockDry aluminum decking which will create a waterproof surface across the entire deck and make the under side a little dryer. However, I have a gutter running through the deck.
I plan to add pavers under the deck and potentially screen it in at some point.
I'd like suggestions on what to do with this gutter.
Off the top of my head, I can think of:
1. Let it dump out on the deck, which will cascade over the deck and mostly off the opposite side (once the LockDry is installed). Some of my gutters have accumulated shingle "pebbles" and I imaging that might end up staining the deck.
2. Bring the gutter forward at nearly a 90 degree angle and keep it toward the top of the underside deck ceiling. But, I'm not sure what to do with it when I get it to the edge of the deck.
3. Leave it as is and dig a trench to put in a pipe that routes the water underground and under the pavers and further out into the yard. Or, to the right where the other gutter is.
There may be much better ideas and that's why I'm here.
What do you all think?
Thanks,
Joe
Joe Schofield is offline   Reply With Quote
Old 08-17-2018, 11:55 PM   #2
retired framer
Rewards Points: 15,446
Re: Ideas on avoiding this gutter through the deck
Do you have a slope on that deck?
Leave the downspout where it is and down stairs install a pipe to take it out to day light beside the other one.
Old 08-18-2018, 08:20 AM   #3
Rewards Points: 1,212
ugly idea = run it over the top of that window to the other side.
yeah, i know, just say'n
not as bad, could be made to work = same thing, but under the window, close to decking, to the other side
roofermann and craig11152 like this.
Fix'n it is online now   Reply With Quote
Old 08-18-2018, 08:55 AM   #4
roofermann's Avatar
Rewards Points: 737
I think under the window, while still ugly would be the more attractive of those options.
craig11152 likes this.
roofermann is offline   Reply With Quote
Old 08-18-2018, 10:11 AM   #5
craig11152's Avatar
Rewards Points: 1,220
I think either option above makes sense.
I would substitute "ugly" with "unconventional" and then mix me a few vodka gimlets till unconventional sticks.
roofermann likes this.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
PatChap (08-18-2018)
Tags
aluminum decking , deck , gutter
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Looking for ideas to adjust drainage for well deck centerisl Building & Construction 2 07-23-2012 10:34 AM
Yankee gutter resurfacing options miamicuse Roofing/Siding 24 01-06-2012 08:20 AM
Deck renovation ideas Army80 Landscaping & Lawn Care 6 04-14-2011 08:15 PM
Grooved Edges of IPE deck - Ideas needed! BSponz1 Building & Construction 1 06-28-2010 10:32 AM
