How To Flash/seal This Spot Where The Roofs Connect? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-11-2019, 09:42 AM   #1
Rewards Points: 129
How to flash/seal this spot where the roofs connect?
I have a leak where the newer garage roof meets the original house riof. Iíve peeled away the roofing and have to try and replace as much of the rotted wood that I can. It look like this was never sealed correctly.
How is meeting point like this sealed to prevent future water leaks?
Maine1 is offline   Reply With Quote
Old 05-11-2019, 02:37 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 408
Re: How to flash/seal this spot where the roofs connect?
Cross reference https://www.diychatroom.com/f9/no-pa...ingles-658865/
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-11-2019, 03:03 PM   #3
retired framer
Rewards Points: 872
This wood should be 1' off the plywood so the shingle go all the way up under it.
If we don't leave enough room the roofers just cut it with a circular saw and then they have 1 1/2", not sure how they deal with the shingles right there. that includes the 2x4 behind the white board.
Besides all that you are looking at, do you not have any ceiling joists or rafter ties in the lower third of the rafters. I think the roofing should stick out 3/4 to 1" from the side or have a drip edge.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-11-2019, 03:22 PM   #4
Rewards Points: 129
Here where Iím at now. I can replace most of the rotted wood but I really have no idea how to seal this up?
Looking online, I see many similar looking repairs but all are setup where the fascia stops at the roof. Mine goes into the roof and passes through a he shingles. How the hell can this be sealed up?
Any ideas would be appreciated!
Old 05-11-2019, 03:47 PM   #5
retired framer
Rewards Points: 872
Cut 1 1/2" of that rake board out and cut a slot into the plywood so the top cap of the garage roof will go in under the shingle from the main roof.
How to flash/seal this spot where the roofs connect?-roof-change.jpg   How to flash/seal this spot where the roofs connect?-roof-change-2.jpg
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
Maine1 (05-11-2019)
Old 05-11-2019, 07:24 PM   #6
Rewards Points: 129
Thanks! I like that idea.. Iíll see if I can make it happen. Trying not to open up too much more of the roof but I can go a little deeper to get that done.
Old 05-11-2019, 07:26 PM   #7
Rewards Points: 129
Should I cut out a larger section of the plywood so I can put a solid single piece covering the seem? (See my pic).
Old 05-11-2019, 07:41 PM   #8
retired framer
Rewards Points: 872
If it has rot, or if it makes you feel better.
BTW anything that has water stains that you are leaving in place. Paint that with copper like the stuff for treated lumber, kills mold, mushrooms and rot.
figure 7-14
Installing new ceiling light where one did not exist badgerman81 Electrical 10 11-01-2016 06:38 PM
How to connect wireless light switch receiver? tmcdanel Electrical 2 09-22-2016 09:52 PM
best way to connect black wire? gregPerson Electrical 2 02-15-2016 12:07 PM
I hope this is the right spot. ffdanf Electrical 8 04-27-2008 10:27 PM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 11:35 AM
