How To Extend Rubber Membrane - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 1 Post By de-nagorg
  • 1 Post By Guap0_
  • 1 Post By nelaco
  • 1 Post By nelaco
Old 09-21-2018, 04:07 PM   #1
Rewards Points: 60
How to extend rubber membrane
Hi group, I have two flat roofs with small leaks.
The rubber membrane looks fine but when installed (before I bought the house) they didn't wrap it around the edges of the roofs. I am pretty sure this is the reason they are leaking. They are at least 15 years old.
Does anyone know how I should go about extending the membrane? Also, what kind of sealant should I use around the edge that won't get extended? About 5 years ago a roofing company installed the nails you see all around the higher roof, and then sealed all around. I need to re-seal again.
Thank you for your help.
How to extend rubber membrane-20180921_085820.jpg   How to extend rubber membrane-20180921_085507.jpg   How to extend rubber membrane-20180921_085106.jpg
nelaco is offline   Reply With Quote
Old 09-21-2018, 04:13 PM   #2
JUSTA MEMBER
Rewards Points: 3,786
Re: How to extend rubber membrane
Flex-Seal products.
I scoffed at their sales pitches on TV, until I had nothing to lose, and tried it.
I was amazed at it's ability to stop leaks.
They have liquid in cans, spray cans, and a tape that is supposed to be good.
look them up and see if you can use something they sell.
ED
craig11152 likes this.
de-nagorg is online now   Reply With Quote
Old 09-21-2018, 04:27 PM   #3
Guapo
Rewards Points: 11,950
I scoff at them too for the simple reason that they use fake bricks when the demonstrate their adhesive product. Even if the product does what they say that it does, no one is strong enough to lift 4 bricks from the top brick with one hand.
de-nagorg likes this.
Guap0_ is offline   Reply With Quote
Old 09-21-2018, 04:38 PM   #4
JUSTA MEMBER
Do you remember the old TV Brick?
Years ago, someone invented a brick shaped foam thing that was designed to throw at your TV when someone ( politician), said something that you did not like.
I don't know if they ever sold much, but I remember seeing their ads.
I've never tried to lift 4 bricks like they do, but I too doubt that puny he can do it.
ED
Old 09-21-2018, 04:51 PM   #5
sestivers's Avatar
Rewards Points: 477
Aren't the bricks in water? That would make them substantially easier to lift...
Steve
sestivers is offline   Reply With Quote
Old 09-21-2018, 05:10 PM   #6
Guapo
No, he lifts the bricks as he glues them one at a time.
Old 09-21-2018, 05:26 PM   #7
Rewards Points: 1,258
Here's how you seam it:
. Not sure it work in your case because you should tuck the patch under the existing membrane, and it might be kind of hard to clean the underside of the existing. Maybe you could do something with cover tape.
Don't think much of those nails. Someone didn't know what they were doing. I'd question the wisdom of trying to extend it vs replacing the whole thing.
Marson is offline   Reply With Quote
Old 09-21-2018, 05:41 PM   #8
Rewards Points: 60
Thank you all.
I'll try Flex seal.
The quote I got to replace both roofs was 11k! this is why I am trying to just fix it instead.
Old 09-21-2018, 06:21 PM   #9
Rewards Points: 1,042
This stuff is highly rated also.
https://www.walmart.com/ip/Eternabon...YaArkoEALw_wcB
Canarywood1 is offline   Reply With Quote
Old 09-21-2018, 07:26 PM   #10
Rewards Points: 60
Thank you, good to know.
Old 09-21-2018, 09:14 PM   #11
JUSTA MEMBER
Originally Posted by nelaco View Post
Thank you all.
I'll try Flex seal.
One more tip that I found , when using the spray can, it is best applied in several light thin coats, over a few days time.
It covers better, and builds up better in layers.
one thick coat will puddle and run off , wasting your expensive experiment.
ED
Old 09-22-2018, 04:19 AM   #12
Rewards Points: 60
Noted. Thank you.
Old 09-23-2018, 12:57 PM   #13
craig11152's Avatar
Rewards Points: 1,220
The rubber membrane looks fine but......
Just for clarification and for potential compatibility issues that roof looks an APP torch down. Maybe an SBS but I never knew them to be smooth surface.
It doesn't look like an EPDM which would be a synthetic rubber.
Do you know what exactly it is?
If its an APP there will be seams every 36".
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 09-26-2018, 05:15 AM   #14
Rewards Points: 60
You are probably right. It does have seams every 36". I don't know exactly what it is but sounds like APP for what you described.
I got another estimate and it is just as high. I am thinking on doing them myself using PVC rolls in the spring. I'll start with the smaller (and lower) one to get some practice. For now I just patched them.
Waterproofing membrane installation against sloped foundation homeimproverjoe Landscaping & Lawn Care 3 04-09-2017 05:09 PM
rubber roof on a deltec? drywallfinisher Roofing/Siding 11 08-28-2013 09:13 PM
Where rubber roofing and asphalt shingles meet... mmerkes Roofing/Siding 6 08-23-2013 06:23 PM
EPDM Rubber Membrane Roofing Q's flatlander745 Roofing/Siding 1 04-01-2011 06:44 PM
Shower membrane mc52 Building & Construction 2 01-27-2007 09:59 PM
