To Expose Or Not To Expose? Lightening Protection Strip - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree6Likes
  • 3 Post By Talos4
  • 1 Post By Talos4
  • 2 Post By Talos4
Old 01-24-2018, 01:37 AM   #1
Rewards Points: 8
To expose or not to expose? Lightening Protection Strip
Hello everyone,
This is my first question on this forum so please excuse me if this is something that is fairly obvious. I've done a bit of googling on this but can't seem to get anything substantial.
Mine is a four story apartment with the apartment owner at the top having access to the roof. There is a metal strip which runs along the edge of the roof and as per the builder this strip is attached to a metal pole on the extreme top of the block of apartments and is used to dissipate lightening to the ground during rough weather.
The picture of the strip(s) as they appear today are given below. My questions is - Is it absolutely necessary to leave these strips exposed as they are in the picture attached or can the strips be covered with cement exposing only the largish screws (as one is visible in the picture) at regular intervals?
We're gonna be using the roof and the idea of exposed metal strips looks ugly. Although, if its absolutely required then we don't have a problem.
To expose or not to expose? Lightening Protection Strip-whatsapp-image-2018-01-20-11.43.42-am.jpg
sandyraw is offline   Reply With Quote
Old 01-24-2018, 05:22 AM   #2
craig11152's Avatar
Rewards Points: 1,176
Re: To expose or not to expose? Lightening Protection Strip
The roof of a commercial structure generally looks "ugly". I would embrace it for what it is.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 01-24-2018, 07:45 AM   #3
Commercial Flat Roofing
Rewards Points: 205
At a MINIMUM you "could" paint the conductors to match the coping. However DO NOT paint any of the bonding connections, conductor splices or any strike points.
Now having said that, leave it alone. Lightning protection is not designed with aesthetics in mind.
We have many customers that have very nice rooftop decks, green roofs etc that just accept the lightning protection as part of the rooftop experience.
Talos4 is offline   Reply With Quote
The Following 2 Users Say Thank You to Talos4 For This Useful Post:
craig11152 (01-24-2018), sandyraw (01-24-2018)
Old 01-24-2018, 09:41 AM   #4
Rewards Points: 8
Thanks @craig11152 , perhaps it isn't clear but this is not a commercial structure. It's a residential apartment with roughly 1000 sq ft usable roof on which we intend to create a roof garden at some point in future.
Old 01-24-2018, 10:07 AM   #5
craig11152's Avatar
I sort of lump "commercial" in with multi (four) story apartments in that structurally they are not designed as single family homes.
Is there any HVAC of any sort up there?
Old 01-24-2018, 10:52 AM   #6
Rewards Points: 8
Thanks @Talos4 for sharing your experience. Your advice is exactly what I was hoping for!
Old 01-24-2018, 10:54 AM   #7
Rewards Points: 8
No HVAC. Just plain roof as it is visible for the adjacent apartment in the picture I've attached above.
Old 01-24-2018, 01:37 PM   #8
Rewards Points: 205
Good example of what a Rooftop Green Roof and patio area can be.
To expose or not to expose? Lightening Protection Strip-img_3369-medium-.jpg
sandyraw likes this.
The Following User Says Thank You to Talos4 For This Useful Post:
Old 01-24-2018, 01:59 PM   #9
craig11152's Avatar
Were you involved in that? I wonder how much weight that adds to the roof system?
As amazing as those look I always think from a roofing standpoint what a nightmare it will be when a leak springs up eventually.
Old 01-25-2018, 07:33 AM   #10
Rewards Points: 205
Yes, It's actually on our facility. We use it as an example to potential green roof customers what a green roof is. We use the patio for lunches, occasional meetings, social gatherings etc.
Weight depends on the type of green roof system installed.
Thumbnail: Anywhere from 10-25 lbs per sqft to 40-100+ lbs per sqft.
Three different types of green roof systems, Extensive, Semi Intensive and Intensive. Weight is based on soil types and plantings.
Of course a structural study must be completed before going forward.
Leaks aren't really a large issue. Many green roofs incorporate a low voltage Electric Field Vector Mapping (EFVM) system.
Basically a wire grid system installed under the non conductive roof membrane and connected to the conductive structural decking.. If a leak occurs the water reaches the wire grid causing a completion of an electrical connection. A scanner then isolates the location and then we know where the leak is occurring. We then remove the overburden and inspect the membrane and complete the repair. That's the thumbnail explanation.
There are also systems that are belt and suspenders system where additional bitumen waterproofing is installed to the non conducting decking (concrete), perimeter walls, penetrations etc, then insulation and roof membrane, overburden are installed. More expensive but, also comes with a leak free guaranty.
There is much more to green roof systems, I've just given the high points.
Here's another one we did on a museum roof.
To expose or not to expose? Lightening Protection Strip-maw-green-roof-oct-08-013-medium-.jpg
Old 01-25-2018, 10:22 AM   #11
craig11152's Avatar
fascinating...thanks for the post
The Following User Says Thank You to craig11152 For This Useful Post:
Talos4 (01-25-2018)
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
How does grounding work? scyarch Electrical 44 06-12-2012 04:59 PM
What kind of surge protector to get for these items baby327nd Electrical 27 10-06-2011 03:35 PM
