Cutting A Hole In A Low Pitch Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 2 Post By chandler48
  • 1 Post By Windows on Wash
  • 1 Post By 3onthetree
Old 06-30-2019, 07:29 PM   #1
Rewards Points: 870
Cutting a hole in a low pitch roof
I need to cut 2 holes into a low pitch roof (essentially flat). Im venting a kitchen range hood and a dryer duct.
The plan is to:
  • drill a pilot hole in the roof b/w two joists. Leave the drill bit in the hole, climb up to the roof and find the bit.
  • From the roof I'm going to trace the vent pipe onto the roof
  • Cut the hole with a jig saw
  • Apply roof mastic to the underside of the roof vent's flanges and secure into the hole.
  • Drill a few screws around the outer edges of the roof vent's flange to secure
  • Roof mastic the screw heads
  • attach the ducting from the inside the building
Is this a good plan? What would you guys do differently?
Here's a pic of the roof vent.
jaketrades is online now   Reply With Quote
Old 06-30-2019, 07:40 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 936
Re: Cutting a hole in a low pitch roof
Nope, not a good idea at any cost. Almost flat and slight angled roofs are not meant for venting and will absolutely leak. Have you looked into the possibility of soffit venting?
Windows on Wash and Dave Sal like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-30-2019, 07:49 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,872
What type of low pitch roof system is it?
Old 06-30-2019, 07:52 PM   #4
Property Mgt/Maint
Rewards Points: 7,436
What kind of roof is it? Metal, asphalt, rubber?
[political signature removed]
Yodaman is offline   Reply With Quote
Old 06-30-2019, 07:55 PM   #5
Rewards Points: 870
Thanks Chandler!
IT's a very old 3 family building (100 years old) and it doesn't have a soffit. I'll take pics tomorrow.
What if i build a pitch box on the flat roof?
Roof pitch box video:
I have a few current roof penetrations. Two plumbing vents, skylight, louvered air vent, roof ladder.
Both plumbing vents and the louvered air vent have leaked recently. Fortunately the top floor is being renovated and I can spot and repair the leaks when it's raining. Nothing serious, but I get your point.
Old 06-30-2019, 07:57 PM   #6
Rewards Points: 870
Asphalt.
I'll take some pics tomorrow. I'll also take some pics of the neighbor's newly renovated roof highlighting his roof penetrations.
Old 06-30-2019, 08:11 PM   #7
It can be done although through a side wall is preferable. How you tie it back depends entirely on the system that the roof is based on.
jaketrades likes this.
Old 06-30-2019, 08:14 PM   #8
Rewards Points: 870
Pics tomorrow morning. thx
Old 07-01-2019, 07:25 AM   #9
Rewards Points: 870
Ok here are some pics. All labeled.
Cutting a hole in a low pitch roof-img_5409.jpg   Cutting a hole in a low pitch roof-img_5410.jpg   Cutting a hole in a low pitch roof-img_5416.jpg   Cutting a hole in a low pitch roof-img_5417.jpg
Old 07-01-2019, 08:38 AM   #10
Rewards Points: 1,886
That looks like rolled asphalt roofing. Yes?
huesmann is offline   Reply With Quote
Old 07-01-2019, 09:06 AM   #11
Rewards Points: 870
I believe so. I dont know much about roofs.
Old 07-01-2019, 12:37 PM   #12
Hammered Thumb
Rewards Points: 788
I would not use that style of vent termination on a flat roof in NY, unless you like water or snow getting in or blocking the air path.
Again, I think you need to really pre-plan (I know I'm a thorn in your side about this) the entire building including all of these vents. You will have 3 vent hoods, 3 dryers, 3 or 6 bath exhaust, and don't remember about the existing furnace/boiler/wh, and 8 or nine plumbing fixtures each floor. Not to mention make-up air you might need and proper attic venting. That's a lotta holes in this roof, and if you terminate them separately, but combine the risers in vertical chases through the 3 floors it will be a little crowded when they terminate out the same point on the roof.
Code addresses minimum distances vents from intakes, from alleys/lot lines/adj walls, height, etc. You should be thinking either curbed risers, extended goosenecks, or capped pipes like the neighbor.
I know you're trying to do this under the radar, and don't want to call attention by renting a bucket to put holes up high in the exterior walls, but there are many issues that keep arising from this project that having pros onboard could have thought about it first.
3onthetree is offline   Reply With Quote
Old 07-02-2019, 08:54 AM   #13
Rewards Points: 870
@3onthetree - You're not a thorn in my side. You ask great questions and really make me think things out further. It's appreciated.
My plan for ventilation on the 3rd (top floor) is to vent out of the roof. Range, dryer, and 2 bathrooms.
On the 1st and 2nd floors, I will ventilate out of the back of the building through the wall.
As you mentioned its an access issue. Without setting up scaffolding I cannot get access to the back of the 3rd floor.
Vent termination: I am planning on raising the vent off the ground 3' to prevent it from getting buried in snow. Good point on using a capped rain pipe or gooseneck.
The attic is ventilated through a ridge vent on the skylight and that louvered metal box.
Old 07-02-2019, 10:38 AM   #14
Rewards Points: 870
If i use a pitch pan, with vent pipe protruding through:
1. What type of foam should I fill the pitch pan with?
2. What goes on top of the pitch pan to cover it?
Cutting a hole in a low pitch roof-master-flow-vent-pipe-flashing-sppo6x6-64_1000-1-.jpg
Old 07-02-2019, 12:31 PM   #15
Rewards Points: 870
I see a roof in my area using pitch pan boxes for their penetrations.
