Corrugated Metal On Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By uncleGarage
Old 06-27-2020, 11:34 PM   #1
Rewards Points: 8
Corrugated Metal on Rafters
Hello.
I was hoping to get advice on how best to fasten corrugated metal to rafters.
This is for a gable-end awning that extends out about 14 feet from the gable. We have 2x6 rafters every 22 inches. I'm not sure if I should lay out 2x4's across the rafters perpendicularly or if I should sheet the whole surface with ply or possibly even t1-11. (t1-11 would give it a nicer appearance from below.
My main concern is getting enough bite when I screw through the valleys on the corrugated and into the underlying wood. But I don't want the screws to break through and be visible from below.
My preference is to use 3/4" T1-11 for the best appearance from below
Thank you very much.
/ug
uncleGarage is offline   Reply With Quote
Old 06-28-2020, 12:02 AM   #2
Rewards Points: 4,220
Re: Corrugated Metal on Rafters
What wind zone are you in?
I would put 2x4s perpendicular to the rafters, either between or on top of the rafters. Then I would put a ceiling on the bottom of the rafters.
Old Thomas is offline   Reply With Quote
Old 06-28-2020, 03:20 AM   #3
retired framer
Rewards Points: 15,462
You can do the plywood face down then horizontal 2x4 straps ever 2ft on top the plywood.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-28-2020, 04:35 PM   #4
Rewards Points: 8
Thanks OT. That's a good idea. I can even use a much thinner and lighter material on the underside as it should get any weather.
I'm in SoCal, inland so I think that's Z1. It's also located in a canyon lower than the surrounding land.
Thanks again!
Old 06-28-2020, 04:36 PM   #5
Rewards Points: 8
This would definitely give me more than enough meat to bite into. Thanks for this suggestion. I appreciate your response.
ug
Nealtw likes this.
