Copper Roofing? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By PatChap
Old 03-07-2019, 09:59 PM   #1
Rewards Points: 2
Copper roofing?
I own a house build in 1863. There are multiple small second story porches with living spaces below. I need to replace the roof material which is doubling as the porch floor on these small porches. There is rolled asphalt there now which is not really suitable for traffic and I have no idea what the original material was. I am thinking of installing copper due to durability. These decks are only approx 7x5 foot. Is it possible to just use a single sheet, or would there be expansion/attachment problems? Is copper not a good material for this purpose? If not, what should I use that would hold up to traffic? Thanks in advance guys!
Irish1886 is offline   Reply With Quote
Old 03-07-2019, 10:07 PM   #2
retired framer
Rewards Points: 22,180
Re: Copper roofing?
Do not use flat bottom gables with scissor trusses.
Old 03-08-2019, 07:20 AM   #3
Rewards Points: 1,092
Re: Copper roofing?
Copper would be a great option, if you never,or rarely walked on it. It would need to be flat locked, and isn't a cheap option.
If the door threshold is high enough off the roof, you could get a regular flat roof and use walkpads.
Otherwise the trafficable Pvc, posted above is probably your best bet.
PatChap is offline   Reply With Quote
Tags
copper , deck , roof , roofing , victorian
Flashing and roofing material overlap sdrocker Roofing/Siding 6 01-30-2018 09:49 AM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 09:23 AM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
