Aluminum Nails Aarrgh - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 3 Post By XSleeper
  • 2 Post By joecaption
Old 10-12-2017, 10:14 PM   #1
CodeMatters's Avatar
Rewards Points: 7,942
Aluminum nails aarrgh
Aluminum nails for fascia etc are a major pain.
Will steel nails will end up with rust streaks?
Is the problem galvanic action or simple rust?
Painted steel nails any better?
Any other options?
Thanks.
CodeMatters is online now   Reply With Quote
Old 10-12-2017, 10:24 PM   #2
Rewards Points: 1,713
Re: Aluminum nails aarrgh
You want painted stainless steel nails. The best ones will be ring shanked.
https://www.mazenails.com/nails/3/25...ted-trim-nails
XSleeper is offline   Reply With Quote
Old 10-13-2017, 12:38 AM   #3
Rewards Points: 6,310
Any other options?
Thanks.
Bore a hole about a third to half the nail diameter for the nail to follow and the nail won't be such a pain.
Old 10-13-2017, 06:47 AM   #4
I've tried that and it helps, but not as much as I thought it
would. I'll see if local hardware stores carry the painted stainless
nails recommended by @XSleeper .
Old 10-13-2017, 07:39 AM   #5
Rewards Points: 18,954
If not there, any real siding supply will have color matched trim nails.
roofermann and CodeMatters like this.
Old 10-14-2017, 06:45 AM   #6
Rewards Points: 8,643
Are you using a retractable nail set for siding nails? It really helps with the bending. Even the box stores carry SS painted nails.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Question on home inspection & aluminum wiring thinksincode Electrical 11 07-05-2013 08:33 PM
Hot Water Anode: Aluminum vs Magnesium zootjeff Plumbing 4 12-14-2012 03:41 PM
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 10:26 AM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
