5inch Vs 6inch Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By SeniorSitizen
  • 1 Post By KHouse75
  • 1 Post By PatChap
  • 1 Post By lenaitch
Old 11-13-2018, 09:22 PM   #1
Rewards Points: 84
5inch vs 6inch gutters
We're going to do new gutters on a house that had the existing gutters removed. I see there's 5 inch and 6 inch gutters. Other than the obvious that one is bigger than the other, is there really a benefit to getting a 6" gutter over a 5" one? This is an investment property, so we're looking to control costs of course, and the 5" ones can save us some money. But we don't want someone to look at the house and think, "Well, it's great, but I need to replace the gutters in a couple years." Or anything like that.
One story house. Total gutter run is about 30' in the front, 7' on the side, and 36' in the back.
mramj4 is offline   Reply With Quote
Old 11-13-2018, 10:02 PM   #2
Rewards Points: 3,144
Re: 5inch vs 6inch gutters
A vote for 5"since most gutters are plugged with leaves/debris and a plugged 5"will drain just as much water as a plugged 6".
Johnny_inFL likes this.
Old 11-14-2018, 01:36 AM   #3
Rewards Points: 1,251
We use plain 5" here even on the monster houses. Unless you use larger downspouts, there's no advantage to using 6". I've never seen a 5" gutter not handle even the heaviest of rains on the largest of roofs provided the correctly sized holes are punched for the downspouts. Larger downspouts would be lots more bucks because they are usually not stocked items.
One thing that really annoys me with gutter installers is when I see 2.5" holes drilled for the downspouts. Why would one install a 3x4 downspout and only drill a 2.5" hole?! The dang tool to punch a full 3x4 hole is under $250. It's done out of pure laziness.
KHouse75 is offline   Reply With Quote
Old 11-14-2018, 05:06 PM   #4
Big Dog
Drachenfire's Avatar
Rewards Points: 4,272
Concur on the 5". The only reason I would see using anything bigger is if you had a flat roof.
My parents home has a flat roof that even 6" gutters could not handle (we tried). We had to custom make 10" gutters out of 1x10s connected to a 6" downspout to handle the water flow.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is online now   Reply With Quote
Old 11-15-2018, 07:18 PM   #5
Rewards Points: 1,110
If you have a large roof surface, 6" helps quite a bit. They also don't get clogged as bad. 5" works fine on most homes.
PatChap is online now   Reply With Quote
Old 11-15-2018, 07:20 PM   #6
Even worse, I cut outlets with snips. Takes me under 30 seconds to cut an outlet or an x, I can't imagine under sizing a drain hole.
craig11152 likes this.
Old 11-16-2018, 08:34 AM   #7
Rewards Points: 7,457
I am inclined to think that a 3x4 downspout should allow minor leaf deposits to pass more easily than a 2x3 but my question is do you have actual experience to support your statement or is just an untested opinion like mine?
Irregardless of your answer I will probably the concept with one downspout.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 11-16-2018, 09:41 AM   #8
craig11152's Avatar
Rewards Points: 1,220
I always used snips too but I tip my hat to you because the best I could ever do was 30.16 seconds.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
PatChap (11-16-2018)
Old 11-16-2018, 11:23 PM   #9
Usually Confused
lenaitch's Avatar
Rewards Points: 646
Purely anecdotal but we are surrounded by trees and the gutters often get plugged despite my best efforts, and during heavy rains they would often overflow. Last year we had the gutters replaced; same size gutters but larger downspouts. They still get full of debris but we haven't had an overflow.
Colbyt likes this.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Tags
gutter
Rust on Aluminum Gutters Medic-5150 Roofing/Siding 9 12-12-2017 06:37 AM
new gutters done and have a question charles3526 Roofing/Siding 16 06-20-2016 05:01 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 09:25 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 01:42 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 10:36 PM
