Tiling Around Toilet - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 12:42 AM   #1
Tiling around Toilet
Trying to finish up a bathroom tiling project, but have never tiled around the toilet. Based on the picture, am I good to go ahead and set it, or do you think I need more tile around the floor flange?
Thanks for your thoughts
Gerard
Tiling around Toilet-image-1935518589.jpg   Tiling around Toilet-image-1459541471.jpg
gerardswork is offline   Reply With Quote
Old 07-27-2012, 05:42 AM   #2
Rewards Points: 3,130
Yes, I think you do. But to be sure, just temporarily set the toilet on the flange and you'll be able to tell.
Old 07-28-2012, 08:18 AM   #3
closet flange hole in tile
Take an angle grinder with a masonry wheel and Mark the opening Plus half inch on all sides. Place tile on work bench over top of cardboard. The cardboard is so the vibrations from cutting tile don't crack the tile itself. Cut the line. Or as my buddy does, cuts and octagon so as to the size of closet flange.
Jeffrey James is offline   Reply With Quote
Tiling the toilet area cbuck Tiling, ceramics, marble 1 03-19-2012 10:21 AM
Installing a new toilet flange - before or after tiling WoodmanFL Plumbing 9 01-21-2012 08:29 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
