Tile To Tile Transition - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-13-2019, 11:15 PM   #1
Rewards Points: 8
Tile to tile transition
Hi fellas,
I mentioned in my last thread that I tore up about 300sqft of carpet and intend to put down 6x24 porcelain. I came across an issue on which I was hoping to get an opinion.
The large room to be tiled is connected with a foyer which is already tiled over, and I was hoping not to tear up that tile. The problem is that the new tile sits a full 1/8th inch above the tile it borders in the foyer, and that's not including the thinset. Does anyone make stone or tile transitions that increase the height over a certain thickness?
Was wondering if you guys had any ideas.
Thanks.
Atreus21 is offline   Reply With Quote
Old 05-14-2019, 05:54 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 798
Re: Tile to tile transition
How many feet of transition are you talking about? Do you have pictures you can share with us?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-15-2019, 12:43 AM   #3
Rewards Points: 8
Sorry it took so long. Here is the total length of the transition, about 70 inches. The black tile is what I want to keep.
This is a close up of the corner. The distance between where the toe mulding ends and the corner of the floor molding is 1-5/8ths inches.
Tile to Drywall Transition Help! brad81 Kitchen & Bath Remodeling 4 08-24-2018 11:52 AM
Best carpet to tile transition when carpet doesn't overlap? Studly Flooring 6 03-27-2017 07:11 PM
Assistance with tile layout / transition between cement board and drywall JeffreyMCooper Tiling, ceramics, marble 4 08-20-2011 12:47 PM
Tile landing Carpet stair Transition Tmint Flooring 1 02-04-2011 05:35 AM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 01:55 PM
