Tile Keeps Chipping In Tile Saw - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By jlhaslip
  • 1 Post By MLMIB
  • 1 Post By chandler48
Old 03-10-2018, 11:07 PM   #1
Rewards Points: 396
Tile keeps chipping in tile saw
I have a wet saw with a new diamond blade but when I keep running my tile through it has small chips in the top coat (the pattern) along the edge. Nothing huge, so for the cuts at the top and bottom of the shower I could live with it but for the edging around the soap dish it'll drive me nuts, any tips?
Does the old fashion tile cutter do a better job at avoiding chips on the topcoat?
thanks for the help!
MLMIB is offline   Reply With Quote
Old 03-11-2018, 01:03 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Tile keeps chipping in tile saw
What style of blade are you running? Segmented or continuous rim? That might make a difference.
Also, cheaper blades will do that, too. The lesser value blades do not run true.
chandler48 likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-11-2018, 05:30 AM   #3
JUSTA MEMBER
Rewards Points: 3,526
Try cutting with the tile flipped over, or adjust the rate of feed of the tile, Also a rubbing stone, will smooth up those little chips so you can't tell they are there.
ED
de-nagorg is online now   Reply With Quote
Old 03-11-2018, 07:26 AM   #4
Rewards Points: 396
using a RIDGID 7 in. Premium Tile Diamond Blade. It's continuous rim with laser cut slots, should show up on the home depot website. curious for your thoughts on if it's the blade. I have a cheaper blade that doesn't have the laser cut slots that I might give a try.
Old 03-11-2018, 07:27 AM   #5
Rewards Points: 396
ED
I tried flipping it and also running it slow, that didn't seem to have any impact. I'll certainly run out today and pick up a rubbing stone and give that a shot, thank you for the advice!
de-nagorg likes this.
Old 03-11-2018, 08:16 AM   #6
retired painter
Rewards Points: 1,318
Don't know if it's right or wrong but I have effectively used a sanding block or electric sander to dress up the edge of a ragged cut.
mark sr is offline   Reply With Quote
Old 03-11-2018, 08:26 AM   #7
Rewards Points: 528
Just curious. What kind of tile saw is it? I had an inexpensive table type saw where I had to push the tiles through it. It did a fair job but it left small chips just like you stated. Eventually I bought a saw where you pulled the saw across the tile and that ended the bad edge. The edge really wasn't bad, just not perfect. The tiles saws without water were no comparison with the wet saw edge.
BayouRunner is offline   Reply With Quote
Old 03-11-2018, 11:01 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
Check whether you have the blade facing correctly.... there is an orientation to the diamond facing in regard to rotation. (But normally that has to do with longevity/wear on the blade)
But, it may likely be just individual to the exact tile you are using.... try a different tile and see if it does the same.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-11-2018, 11:09 AM   #9
Naildriver
chandler48's Avatar
Rewards Points: 3,584
Another thing to consider is the depth of the blade. Again, we don't know what type saw you are using, but a bridge saw can be set to various depths. Also, slow down on your push through. Going too fast can cause burns and chips.
mark sr likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-11-2018, 12:43 PM   #10
Rewards Points: 1,251
It could just be the tile. I've cut lots of tile over the years and sometimes, I get tile that chips easily. I have to slow down considerably when making cuts that will show. I always dress up the edges just a little at a 45 degree angle which gives a much nicer look and removed any minor chips.
KHouse75 is offline   Reply With Quote
Old 03-11-2018, 09:56 PM   #11
Rewards Points: 396
cheap qep wet saw is what i'm using, so it's the push type. the top sliding tile saws seem to be expensive, but maybe I just need to suck it up. it's a shame, I tiled ~1,200 sqft with the cheap tile saw but I think this tile just isn't holding up as well when I cut it and I can't hide the cut edges under molding.
Old 03-11-2018, 09:57 PM   #12
Rewards Points: 396
how did you put the 45 degree edge on? did you do it with a sanding block, or with the tile saw?
Help! Wall Tile Repair with No Substrate? LauraFixItGirl Tiling, ceramics, marble 4 06-06-2013 11:05 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
