Tile On Concrete - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-14-2018, 01:35 PM   #1
Rewards Points: 4
Tile on concrete
I have a house that was built in 64. I am remodeling the bathroom and a friend suggested that i take out the concrete under the tile and start fresh. So, the tile sits on about 3 inches of concrete and under that is the wood subfloor. Should i do that or leave it?
Redfox4 is offline   Reply With Quote
Old 03-14-2018, 02:14 PM   #2
Rewards Points: 4,266
Re: Tile on concrete
Sounds like a mud bed. I would remove it.
stick\shift is offline   Reply With Quote
Old 03-14-2018, 05:15 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 134
IDK.... but if you're just going to need/replace the rise of the mud bed, and it's in good shape after you remove tile, IDK why you'd remove it.
Why does your friend say to remove it.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-14-2018, 06:48 PM   #4
Rewards Points: 2,122
Reads like some of the custom homes my brother built for some more wealthy people back in the 70's. Whenever they had a bathroom or large entry foyer they wanted high quality "mudset" tiles laid in, they had us frame a floor system for the tiles like my goofy sketch.
Probably frowned upon with the newer tile technology today. But was the norm back then it seemed, for the big custom homes where money was no object.
Gregsoldtruck79 is offline   Reply With Quote
Old 03-14-2018, 06:54 PM   #5
Rewards Points: 4
Yup, thats what my friend said, that they spent some money on it. The tile does have a crack running through it, just would be a pain to take it out but i want ir done right.
Old 03-14-2018, 06:58 PM   #6
One can see it my sketch where the weakness in those old systems would be, because if there is ANY deflection in a joist at all, it will break the mudset and tile ....right along the center of the joists, as the mud was only 1.5 in. thick above the joists.
Old 03-14-2018, 07:23 PM   #7
Rewards Points: 4
Here is a picture of the floor,there is a crack (not from my demo job) further up on the tile floor. The whole bathroom was filled with pink tile, floor to ceiling.
Asbestos tile and painted concrete Blueprint68 Flooring 1 10-17-2017 05:57 AM
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 01:34 PM
Need help for raising level of tile for concrete slab. JakeN Tiling, ceramics, marble 5 03-15-2012 02:38 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 08:11 PM
